Hi
I have made a voltage detector circuit using NE555. This gives the right cut in and cut-out voltage (12/10V)
Pin 3 gives -5V when 12Volts is reached.
I need the output to drive a 12VSPDT relay (coil 50mA).
I tried using a 5V relay to drive the 12V relay but it drew too much current 50mA for the 555 as the voltage dropped to 3.3V
I was hoping someone could help me design a circuit that can drive the 12V relay with a Transistor or Fet
I have in stock 2n2222 (old one so not sure if i may have broken it in the past) , 2 off BC557, Tip42C, IRF1405 and IRF740
Thanks
Thanks
