Transistor to drive 12v relay
nickmms
Joined Jan 2, 2014
47
Going back to post #1 you said "pin 3 of the 555 gives -5 volts when 12 volts is reached".
When you say -5 volt from the 555 how are you measuring it, with respect to ground?
I just measured pin 3 and +5V from the 7805 or pin 8 from NE555
nickmms
Joined Jan 2, 2014
47
I think you mean the output of the 555 is 0 volts when the battery is 12 volts.
ill go to the shed and measure things
nickmms
Joined Jan 2, 2014
47
Tested with MM Black and red leads
when the 555 senses >=12Volts
black lead to Pin 3 Red to Pin 8=+5V
Black lead to Pin3 Red to Pin 1 = 0V
sghioto
Joined Dec 31, 2017
8,763
You always measure voltages with the black lead at ground. Anyway that tells me that the output from the 555 is 0 volts when it senses 12 volts.
Try this arrangement connecting the 12 volt relay to pin #7. It's also recommended to connect pin #4 to 5 volts as well.
nickmms
Joined Jan 2, 2014
47
Thanks very much Sghioto yes it runs the relay from pin7.. but I hadn't hooked pin to +5 which I will do
As expected the coil draws 48mA which the 555 can handle.. but just for interest I would like a transistor to run the relay (for learning purposes) do I hook +5V from pin 4 to the base through a 1k resistor and pin 7 to the emitter and collector to +12V?
sghioto
Joined Dec 31, 2017
8,763
No! In this case since the output is low one would normally use a PNP transistor like a 2N3906. Emitter to 12 volts, Collector to top side of relay, other side of relay to ground. Connect the base through a 1K resistor to pin 7.
Other choice one could use two NPN transistors like the 2N2222 wired as an inverter.
I'll post a schematic shortly.
