ELECTRONERD,
Ratch
I don't know what you are trying to do. Vce = 10V is the pulse voltage used for the Vsat measurement. Where did you get Vce = Vcc/Ve from? What are you trying to say?If you look at the specs, for the "Base-Emitter saturation voltage" on page two, you notice that it says "Ic=150mA, Vce=10V." Vce is calculated by the following equation: Vce = Vcc/Ve. So I made 5V at the emitter for my design with a 15V supply, 15V-5V=10V for Vce. You said:
Quote:
Originally Posted by Ratch
Yes, what about it?
So according to you, Vce shouldn't even be mentioned on the specs.
Ratch
