Transistor logical AND circuit
dl324
Joined Mar 30, 2015
18,453
I saw this on google. I don't understand where do inputs A and B take electricity from
It's assumed that they're driven by other logic gates or tied HIGH or LOW to supplies.
It would be better for you to start referring to current and voltage instead of electricity. With bipolar junction transistors (BJTs), it's current that turns them on. With MOSFETs, it's voltage.
Not having an LED in the output of the gates would also be more typical:
When the output is high, the LED is on. When the output is LOW, the LED is off.
Electronic0Noob
Joined Oct 24, 2021
19
Looks like I burned the leds, the potentiometers, the transistors and the power source exploded. At least I have a bunch more leds, potentiometers and transistors. I need to buy another DC power source.
dl324
Joined Mar 30, 2015
18,453
Only your inverter circuit should have damaged anything. Are you certain you're connecting things correctly?
Why and where are you using potentiometers?
A nit. We spell LED with all caps because it's an acronym for Light Emitting Diode. We also spell the acronym when we talk about them, because they're LEDs, not leds.
Electronic0Noob
Joined Oct 24, 2021
19
I bought potentiometers and not resistors because I didn't want to bother with Ohm's law to calculate the resistence needed to drop an amount of voltage. With potentiometers I can adjust the resistence. I use them to drop from 12V to 1.3V(for the LED) and to drop from 12V to 1.0V(for transistors bases)
Papabravo
Joined Feb 24, 2006
22,111
That's fine as long as this is a hobby. Just don't imagine this method as a path to a career.
Electronic0Noob
Joined Oct 24, 2021
19
I am a software engineer. Someday while programming I thought: "I can program this metal thing, but how does it actually work at physical level?" and I am trying just to understand better how is the electricity from the power outlet of my house used by this ingenious machine we use everyday. So it is a hobby and I don't really need this information in my career, however I thought it might be interesting to see how computers were invented.
AnalogKid
Joined Aug 1, 2013
12,256
All of the circuits posted by everyone so far have the same problem - there is no resistor from the base to the emitter of any transistor, to guarantee that the transistor turns off when the base goes open-circuit. This explains the error condition in post #1.
To the circuit in post #6 (et al), add a resistor from each transistor's base to its emitter. You don't say what the base resistor's value is, but the added pull-down resistors should be about 10x to 50x that value.
ak
Papabravo
Joined Feb 24, 2006
22,111
So that would be like me saying maybe I'll bother to learn the syntax and semantics of the language I am using to do my embedded development project. Would you care to opine on my chances of success in that enterprise?
Electronic0Noob
Joined Oct 24, 2021
19
How can I add a resistor from the transistor base to emitter? Does that mean the resistors of the 2 inputs A and B from the following image? Why I need 2 resistors and not just one and split the output of that resistor in 2?
Sorry. I didn't understand...
Papabravo
Joined Feb 24, 2006
22,111
I made an equivalent statement about intellectual laziness from a perspective (software development) I thought you might be familiar with. Apparently I was mistaken.
Electronic0Noob
Joined Oct 24, 2021
19
The problem was that you quoted the part where I told why it is just a hobby. If you quoted the part where I said that I don't want to bother using Ohms law I would have understood the laziness you are talking about.
Electronic0Noob
Joined Oct 24, 2021
19
Don't software engineers have at least one basic EE course required? EE's are required to take a programming class.
Maybe in US. I went to the University of Automations in my country and a took Java Master of 2 years, no basic EE.
The math isn't very difficult.
It is kind of hard to find the electronic components I need and if I miss the ohm value of the resistor I need I have to wait a week to get another.
dl324
Joined Mar 30, 2015
18,453
You could buy a starter kit.
In a pinch, you can use series and parallel combinations to make values you don't have.
