Transistor circuit
Jony130
Joined Feb 17, 2009
5,600
If the circuit is "driven" from an ideal voltage source the gain will be equal to (20k||5k)/1k = 4V/V if we ignore re.
The RB will not be "reflected" at the emitter side due to the ideal voltage source driving the amplifier input.
Zeeus
Joined Apr 17, 2019
616
yeah : was just thinking it..will be Rb || 0 = 0
Please another test..1 more
Zeeus
Joined Apr 17, 2019
616
Oki. but why 19.8? I would say 20.
No, wrong, This one is a tricky.
19.8 because of β/ (β+1)...20 if ratio is 1
Hmm okay...trying again..Thanks
The resistance in the current source is not important?
There is no gain? but attenuation?
Zeeus
Joined Apr 17, 2019
616
I think there is an error(s) in the book.
First: No gain?? I think 330k should be 330 ohms. Now we have gain.
Second: Bias is not right, never was. 6.1k should be 61k
In SPICE I changes the 1V signal on input to 0.5V.
Now the circuit is just strange.
Now Ve2 is at 6.8V or about 1/2 of the 12V supply. That is good.
I think "Vo" is the output not Ve2. Also strange.
With a 0.5V signal in Vin we get Ve2=about 4V and VO=3V peak.
If I was making this amplifier: (note 0.33 ohms could be 0)
in post #12. Do you know how he did the model ".n NPN(BF = 99)? "
Actually : think know mistake for dc analysis : trying
Assumed Ic = Ie
Vb is base voltage of transistor 1
Ve emitter of 2nd
\[ Vth = Vcc - 22k * (Vb-.7)/330 \]
\[ (Vcc-Vb)/6.2 = Vb + ((Vb-Ve)/10) + (Vb -.7)/33 \]
\[ (Ve/4.9) + (Vb-Ve)/10 = 100 * (Vth - .7 - Ve)/22 \]
Please what am I missing? or rather what did I get cos know missed everything
Answer not corresponding
Thanks thanks
ericgibbs
Joined Jan 29, 2010
21,573
hi Z,
In the LTS cmp folder you should find 'standard.bjt'
I have taken a clip of the 2N3904 transistor, BF is the 'Gain' of the transistor
E
C:\Users\ericg\Documents\LTspiceXVII\lib\cmp\standard.bjt
.model 2N3904_100 NPN(IS=1E-14 VAF=100 Bf=100 IKF=0.4 XTB=1.5 BR=4 CJC=4E-12 CJE=8E-12 RB=20 RC=0.1 RE=0.1 TR=250E-9 TF=350E-12 ITF=1 VTF=2 XTF=3 Vceo=40 Icrating=200m mfg=Philips)
.model 2N3904_200 NPN(IS=1E-14 VAF=100 Bf=200 IKF=0.4 XTB=1.5 BR=4 CJC=4E-12 CJE=8E-12 RB=20 RC=0.1 RE=0.1 TR=250E-9 TF=350E-12 ITF=1 VTF=2 XTF=3 Vceo=40 Icrating=200m mfg=Philips)
Zeeus
Joined Apr 17, 2019
616
hi Z,
E
Hmm E,
I do not understand...I found the folder and standard.bjt
nvm...thought could not edit
so can't change it in the simulator directly?
Also seeing TIP, Bc transistors but not available in the simulator
ericgibbs
Joined Jan 29, 2010
21,573
hi Z,
To edit the standard.bjt use a Text Editor.
I would advise you to make a copy of the standard.bjt BEFORE editing any of the components.
An easy way to check out different BF values for a transistor, is make a Copy and Paste of the transistors details.
Rename the Pasted copy
eg :
.model My_2N3904_100 NPN(IS=1E-14 VAF=100 Bf=100 IKF=0.4 XTB=1.5 BR=4 CJC=4E-12 CJE=8E-12 RB=20 RC=0.1 RE=0.1 TR=250E-9 TF=350E-12 ITF=1 VTF=2 XTF=3 Vceo=40 Icrating=200m mfg=Philips)
and Save the standard.bjt file.
To make that edited copy active, close down and restart LTSpice, the My_2N3904_100 should appear in the listing when using F2.
OK.?
E
Another quick fix way is to paste this into your circuit, it works but it looks messy IMO.
Zeeus
Joined Apr 17, 2019
616
Yeah the quick fix.. Unfortunately, still do not follow...Can do something like in the image below?
ericgibbs
Joined Jan 29, 2010
21,573
hi Z,
I have modified your original circuit to demo the BF option.
E
Note:
In order to Paste any text into a LTS circuit drawing.
Copy the text as usual from the Text Editor...
then Press 'S' on the keyboard, then paste the text into that Pop Up box.
Zeeus
Joined Apr 17, 2019
616
hi Z,
E
Note:
Thanks but how did you find it? The My_2n3904 ?
when you press F2? or after pressing F2 and choosing npn?
To make that edited copy active, close down and restart LTSpice, the My_2N3904_100 should appear in the listing when using F2."
not for me
