Neither can I. Someone posted that 13005 has 3 type of casing with Ic ranging from 2A (SOT32) - 4A (TO220). Since your 13005 is in TO220 casing, you can treat it as 4A part and the PHE13005 should be fine as a substitute.I do not understand the difference between the two transistor, Especially the E13005-2. I could not Found the datasheet of E13005-2 either.
0.4V on the collector is too low for the transistor to work. You're measuring the voltage with respect to what?I have checking the E13005-2 which is not short, the value at collector is 0.4035 and at emitter it is 0.0050. Did i also change that transistor with PHE-13005.
Thank you Scottwang. So can i replace the transistor E13005-2 with PHE-13005 in this circuit, or not.I redraw the circuit.
