TR switching and receiving echo signals
28,227
Really, this is simulating the operation of a system used to monitor the position of the ram in hydraulic cylinders. We had a "go-around" with that function a few years back. The capacitor for timing the receive-enable was a bit deffective in the production run units we received. THAT caused a few serious problems.
demir-ali
Joined Jul 13, 2024
324
why is that sir can you explain a bit , it may helps me one day.
28,227
That system sends a magnetic pulse down a steel rod, and when the pulse passes a magnet it sens an electrical pulse back up the rod. So the time difference indicates the distance traveled. The actual scheme is proprietary.
demir-ali
Joined Jul 13, 2024
324
So may it is because the magnetic field or electric field effects upon the cap ?
demir-ali
Joined Jul 13, 2024
324
I did the tests , Lf353 opamp is not good at giving output unless input exceeds the vref too much.
I currently try to use lm393 but it does not work as sim.
ericgibbs
Joined Jan 29, 2010
21,567
Hi demi,
This simulation shows a stepped [V2] Echo from 1mSec to 9mSEc, with a 10mV echo amplitude.
Experiment using echoes signals of different magnitude.
I have used a LM393 in place of the LM2903, it will not change the operation of the circuit.
The swept TGC need a little more work.:)
E
demir-ali
Joined Jul 13, 2024
324
Hi Eric , I see that the error is due to offset exceeds the vref earlier than excepted as I see.
I used an potensiometer to make Vref adjustable. In experiment , this issue did not appear. Is there still a problem ?
Also , when I use a lower resistor at the output of comparator , the input signal breaks why is that sir ?
demir-ali
Joined Jul 13, 2024
324
The only problem is when I set vref a bit more higher , I can start measurement from 30cm but the final signal disappears earlier.
Rc adjustment can solve this I guess.
ericgibbs
Joined Jan 29, 2010
21,567
Hi demi,
Usually, when using a Comparator, some level of Hysteresis is added from the Output to the Non Inverting input. ie; positive feedback via a high value resistor.
How do you plan to use the output pulse?
If it is being detected by an MCU input, all that you are interested in , is the first rising edge of the pulse.
Hint: If you reduce R5 to say 20k, it will reduce the Vout pulse to ~+5V max
Added: and change VDD on R18 to VGND
E
Added a PDF.
demir-ali
Joined Jul 13, 2024
324
Hi demi,
E
Added a PDF.
I do plan to detect it using mcu input.
demir-ali
Joined Jul 13, 2024
324
hi,
Are you going to use a high going Pin Interrupt?
E
Hi , I do know interupt system that I used in stm32 before but I haven't used in arduino yet. I may code an alrogithm that uses digital real rapidly Idk.
The algorithm in my plan is , after the transmit process , setting the active function to waitecho and check for high voltage rapidly.
demir-ali
Joined Jul 13, 2024
324
I've tried it but when I connect the zener setup at the output of comparator , output keeps it's shape but it is under 2v peak pulses.
I guess in case I use an buffer this problem solves but I am using many components and wonder if I do sometging wrong.
demir-ali
Joined Jul 13, 2024
324
Hi , I use this code to send pulse and then detect the echo pulse but arduino does not detect those returning pulses.
Yellow traces are the comparator output , blue ones are the biased and amplified signal.
Btw it may not be the best way of limiting output voltage but I connected a zener diode between comparator output and gnd.
