TR switching and receiving echo signals
28,457
One interesting possibility not mentioned yet would be an AGC controlled amplifier that would try to hold the output level constant by adjusting the gain. Then the actual signal magnitude can be determined by watching the gain control voltage. That scheme is widely used in communication equipment and it works very well.
demir-ali
Joined Jul 13, 2024
324
Sir I researched about TSR and AGC but eventually this setup was what I could made.
demir-ali
Joined Jul 13, 2024
324
Hi , I made this circuit and it seems working. I can upload a video tomorrow. I also bought LM393 , it's on delivery.
Can we discuss about the point I am at after I upload?
ericgibbs
Joined Jan 29, 2010
21,603
Hi demi,
That TGC [ timed gain control ] is not going to work as required.
You require a swept variable gain, not a stepped gain.
After the end of TX output pulse, you require a suppression period, that is, the program ignores the TX piezo resonant decay pulses after the TX period.
Then the swept gain starts with a high attenuation level, which reduces at a linear or exponential rate, up to the time of maximum echo range.
E
demir-ali
Joined Jul 13, 2024
324
I got what you mean as swept gain but could not find any other way to do that. Could you help a little bit more or give some hints on that subjective pls ?
ericgibbs
Joined Jan 29, 2010
21,603
Hi demi,
As you know I cannot post my working circuit, but this shows the plots.
1. V4 is the input to the Comparator, note how the signal stays the same amplitude but rides on a rising ramp voltage.
2. Vref is the other input to Comp
3. Vo is the final output.
4. Vin is the initial input from the piezo.
Hint: think P JFet for the attenuation circuit. eg 2n3820
E
demir-ali
Joined Jul 13, 2024
324
Hi demi,
E
Hi Eric , as looking onto your post , I guess like you have an increasing voltage x and summing our output with it. Than you comparate the output with vref. Is this correct or close ?
In this case I guess it is a different comparating technique but varying gain.
demir-ali
Joined Jul 13, 2024
324
Hi demi,
E
Btw I missread this and guessed the circuit so i am also happy bout this
ericgibbs
Joined Jan 29, 2010
21,603
Hi demi,
This is the limit on the help I can give on your assignment
This version maybe easier for you to follow.
The gain is set to a high value and then attenuated by the jFET in a controlled decreasing level of attenuation.
Work out a circuit and post your results.
Hint: You should have a trimmer potentiometer to set the Gain and Vref
E
demir-ali
Joined Jul 13, 2024
324
Hi demi,
E
Hi Eric , the circuit I posted seems working is there a problem with it ?
ericgibbs
Joined Jan 29, 2010
21,603
Hi demi,
Your scope images show the actual echo signal, do you have a scope photo of the comparator output, which should resemble a square wave?
E
demir-ali
Joined Jul 13, 2024
324
Hi demi,
E
Hi sir , I willl make that stage today. Being able to set echo levels onto Vref without gaining the noise made me happy. I will upllad the comparator output. Btw now I have lm393 , may should I use that ?
