TPS25947: switching between current limits
jwfx
Joined Jan 15, 2025
13
I'm building a product which is powered by PoE/PoE+ and has an output protected by a TPS25947 eFuse.
I need to be able to switch the current limit on this eFuse between 500mA and 1A (at 12V) based on the PoE class that was negotiated. I already have an output indicating the PoE type, I just need a way to switch the current limit on the eFuse.
The current limit is controlled using a resistor from ILM to ground - it appears the way the current limit works is that it "mirrors" the output current onto the ILM pin at a specific ratio (182uA/A) and if the voltage exceeds an internal threshold (~0.6V?) it trips the over-current protection.
I'd need to switch between a 3.3k (3334 / 1A ~= 3.3k) and 6.8k (3334 / 0.5A ~= 6.8k) resistor between ILM and ground.
Is an analog switch my best option? I'd need a 12V switch as ILIM can almost reach 12V (I've seen ~10V on my scope) for a few microseconds if the output of the eFuse is shorted (which is something I want to protect against).
38,864
You could use a small N-MOSFET, such as a 2N7000, BS170, etc.
Connect a 6.65kΩ resistor from ILM to ground, and a 6.65k resistor from ILM to the MOSFET drain with the MOSFET source to ground.
Thus with the MOSFET OFF the resistance will be 6.65kΩ, and with the MOSFET ON the equivalent parallel resistance will be 3.33kΩ.
Alternately you could connect the two 3.32KΩ resistors in series from ILM to ground, with the MOSFET drain connected to the junction of the two resistors, and the MOSFET source to ground.
Now the resistance will be 6.64kΩ when the MOSFET is OFF and 3.32kΩ when the MOSFET is ON.
See no reason to prefer one configuration over the other.
jwfx
Joined Jan 15, 2025
13
I did originally consider using a MOSFET switching a parallel resistor and even started drawing it into the schematic, but I thought the 0.6V Vds would be an issue for some reason.
I think I saw "Vgs = Vds" in the datasheet without realizing it was the test parameters used to find Vgs(th).
Thank you both! I think I am going to go with the parallel resistor and MOSFET (probably using an AO3400 which is overkill but I am already using in my design).
This simulation shows it nicely: https://www.falstad.com/circuit/cir...yg0WmIhSlU0iKUjYAGcPl8xLhLHdrCAOABDAA2YIYbCAA
It has a 182uA source (simulating 1A through the eFuse) - when the MOSFET is off the current limit is 500mA (shown by the 1.208V reading on the voltmeter - double the 0.6V overcurrent threshold) and when it's on the current limit is 1A (shown by the 607mV reading).
sghioto
Joined Dec 31, 2017
8,756
I would change the 10K resistor in series with the switch to 100 ohms.
Improves the Rdson a little better.
jwfx
Joined Jan 15, 2025
13
Yeah not sure why I used a 10k there - I've been using a 200 ohm gate resistor in all of my other designs using this MOSFET!
28,434
You only need one switch. Put the 6800 ohm resistor in full time, and then for the increased current limit connect a second resistor in parallel with it. Much simpler, fewer pats, and no change-over glitches. To control the current accurately you will need at least 1% tolerance resistors.
