TLV3701 negative power supply value use question
28,447
One huge benefit of a simulator over reality is that parts never burn up.
Look at the rest of the data sheet, including the ABSOLUTE MAXIMUM VOLTAGE section, and the power supply section.
The rest of the specifications sheet provides a whole lot of useful and even important information.
Section 8.3 of the spec sheet states that it can be used with a split supply.
yef smith
Joined Aug 2, 2020
1,482
Hello ,the datasheet say Vcc is 17V. my negative voltage input is 4V and positive input is 0V.
If i put in the comparator Vcc=12V and GND=-12V so it will be 24V?
So it will burn the component?
Any alternatives i can find?
Thanks.
28,447
For the positive supply you could use a 5 volt Zener diode and a resistor to provide + 5, and along with the minus 4 volts that should work quite well.
yef smith
Joined Aug 2, 2020
1,482
Hello sarahMCML,my comprator backly needs to pass M12 signal which is 0 to -12V pulse.
positive input is GND, negative input is 4V.
I have placed a spice model of these components and they both gave me a spike of +12V.
When I put RB060MM-30 diode it canceled this spike .
Is it a good solution?
Thanks.
LTspice are attached.
BobTPH
Joined Jun 5, 2013
11,662
Thanks.
The absolute max voltage is the highest voltage at which the chip will operate as specified. What it does with a higher voltage is unspecified. It might burn up, it might shut down to protect itself, or it might just operate less precisely. That said, I would not expect the chip to survive for long with 24V when the max was 17, whereas I would expect it to operate normally at 17.1V.
yef smith
Joined Aug 2, 2020
1,482
Hello Bob, In post 8 when i answered to the good suggestion of SarahMCML, I got an undesired spike of 12V from the model I was suggested.I canceled this spike with RB060MM-30 shotky diode.
Is it a good solution?In the simulation it works.
I upladed the full LTSPICE file in post 8.
Thanks.
sarahMCML
Joined May 11, 2019
705
Thanks.
It may not make any difference to your Spice model, but the TLV1821 is an Open Drain output comparator, whereas your original TLV3701 is push-pull output. You need the TLV1811 version, possibly. Or a pull-up resistor on the TLV1821's output!
