What leaves a cell's negative terminal during charging?
johnyradio
Joined Oct 26, 2012
615
When you charge a battery cell, i assume electrons are entering the positive terminal to get stored in the cell. I assume, since the negative terminal is connected to ground, that ground connection is what creates current flow into the positive terminal -- without a ground connection, the cell wouldn't charge. So what flows out of the negative terminal into ground during charging? If it's electrons, doesn't that discharge the cell?
35,170
Don't over think this problem.
The current flowing into the battery being charged is the same as the current flowing out of the battery.
The charging source has potential energy.
Energy is transferred from the source to the battery. The potential energy of the battery rises.
johnyradio
Joined Oct 26, 2012
615
I think you didn't answer the question.
But i suspect the following:
Nothing flows out of the negative terminal during charging. Rather, it simply creates a voltage attraction, to pull electrons into the positive terminal.
38,797
Absolutely not.
For one electron to leave the battery from one terminal, one electron as to enter, since that is the only way current can flow.
Electrons don't provide the energy, they just carry it.
All the battery does is add energy due to chemical changes, which generates the battery voltage difference between its terminals, which is transferred by the electrons between the two terminals.
BobTPH
Joined Jun 5, 2013
11,645
You assume wrong. When a battery is charging, charge flows into the anode, not electrons. Electrons are negative, so they flow in the opposite direction of charge.
And batteries do not store charge.
35,170
I did answer your question. You just were not paying proper attention.
I said current flowing in and current flowing out are the same. I did not use the word "electrons" because that makes you think of charge accumulation, which is not what is happening.
If you must, imagine you have a piece of wire connected to a battery.
An electron enters one end of the wire and another exits the other end. There is no charge accumulation on the wire.
And yet the wire gets hot. Energy is generated and dissipated as thermal energy. Thus energy is transferred, with no net gain or loss of electrons.
The same happens when the battery is charging. Electrons deliver energy with no net gain or loss of electrons in the process.
Thinking of electron flow in and out of the battery does not explain how a battery gets charged.
johnyradio
Joined Oct 26, 2012
615
You didn't mention electrons because they aren't moving? Or because of what you think it makes me think? You said i shouldn't overthink. What's the correct amount to think? I'm thinking of thinking. What do you think?
This video seems to say charging is all about the transfer of ions inside the cell. If true, that helps me understand why charging is not about electron accumulation.
This article seems to agree that charging is all about the transfer of ions. Somehow, the movement of electrons from the negative to positive terminal through the charger allows or attracts the ions back toward the positive terminal.
When we charge the lithium batteries, the electrons are sent back to the anode and the lithium ions re-intercalate themselves in the cathode. This restores the battery’s capacity.
Are you speaking of ions? This video says ions travel to cathode.
WBahn
Joined Mar 31, 2012
33,182
First off, when you charge a battery, electrons leave the positive terminal and enter the negative terminal. When the battery is in use, it's the other way around.
Forget about a battery for a moment, and think of a capacitor.
When you charge a capacitor, you move an electron from one plate and put it on the other plate (it's not the same electron, but that's irrelevant). If you then discharge the capacitor, electrons move back from the plate that has an excess to the plate that has a deficit.
Notice that the total net charge on the capacitor overall is always zero -- we have just created a separation of charges within the device.
The same is true of a battery in that, at all times, it has a net overall charge of zero. The big difference is that instead of creating a physical separation of charges like we do in a capacitor, we are controlling chemical reactions that store or release energy in the chemical bonds that are created and/or broken. The amount of actual charge separation that exists within a battery is miniscule.
johnyradio
Joined Oct 26, 2012
615
when you charge a battery, electrons leave the positive terminal and enter the negative terminal. When the battery is in use, it's the other way around. it has a net overall charge of zero.
Thx, i'm getting that.
Is the following correct:
The movement of the ions during discharge causes movement of electrons between terminals (through the load), which in turn cause electromagnetic motion in the surrounding wires, which is where the real power (energy?) is.
WBahn
Joined Mar 31, 2012
33,182
If you want to get into where the energy really is, then you need to be talking about the electric and magnetic fields, since that is where the energy resides.
But that may or may not be useful depending on what you are actually trying to grasp.
johnyradio
Joined Oct 26, 2012
615
If you want to get into where the energy really is, then you need to be talking about the electric and magnetic fields, since that is where the energy resides. But that may or may not be useful depending on what you are actually trying to grasp.
At the moment, just trying to grasp cell charging. EM fields was a tangent (get it? :D
35,170
Here is a thought experiment for you.
In this real working circuit, AC voltage is applied to the primary winding of transformer T1.
On the secondary side, battery BT1 becomes charged even though there are no electrons passing from the primary to the secondary winding.
Capacitor C1 is not necessary but just added to emphasize that there is no DC flowing into the transformer.
