TL082CN Non Inverting Amplifier
cookieplz
Joined Apr 23, 2017
8
Hi All,
I am trying to put together a non inverting amp with a gain of 10.
I put it together using a 10k and 100k resistors and the opamp input voltage at 14V form a power supply.
The input signal is fed from a function gen as a sine wave @100Hz and 200mVPP. I breadboarded all of this, but my issue is that the output signal looks horrible, with no signs of it being amplified. I am sure I am doing something horribly stupid, but I could use some insight.
I have attached a couple of photos of the input/ output signals and the breadboard, any help would be appreciated
38,528
As MC noted you need a dual power supply (or you need to apply a DC offset of at least +4V to the signal.)
Alternately you could use a rail-rail type op amp.
cookieplz
Joined Apr 23, 2017
8
Got it.
So I added another power supply channel and connected them as such :
I connected the negative lead of the first channel to the positive terminal of the second channel.
I then connected the negative of the second channel to VCC-
And the positive of the first channel to VCC+
With respect to the negative of the first channel VCC+ = 10V VCC- = -10V. But the waveform still looks about the same, I can take another picture
DickCappels
Joined Aug 21, 2008
10,661
Are your power supplies clean? Did you use the capacitors across the power supplies as absf showed in post #7?
If they are already there, try 100 uf.
cookieplz
Joined Apr 23, 2017
8
I did not have the power supply capacitors :(.
I think things are mostly working now, but I see some bizarre behavior.
If I sweep the frequencies of the input signal from 100 Hz to 1Khz and turn on the voltage to the opamp, the output signal behaves as you would
expect. However after a few seconds I see the following yellow output signal:
Any ideas on what could be causing this?
12,143
Since you know how to post a photo, draw your schematic on a piece of paper. Show every component, every power supply, every signal source, every scope connection, and every component connection. Make sure each component has a unique reference designator. Take a picture. Post it.
absf
Joined Dec 29, 2010
1,968
You need one more wire from the centre of the 2 power supplies to the -ive side of the sig gen.
If you're using TL082, I think pin 4 and pin 8 are backwards. Let me check with pdf again.
Allen
MrAl
Joined Jun 17, 2014
13,709
Yeah, floating input :)
But remember one more little thing...
The gain of a non inverting amp is not R2/R1 it is R2/R1+1. Note that +1 there.
That means with a 10k resistor and 1k resistor the gain is not 10 it is 11.
Likewise, with 10k and 2k it is not 5 it is 6 because we have to add 1.
