TinkerCAD 7-Segment Display Not Showing on Simulation
Swaysceptile
Joined Oct 28, 2021
17
Hi, I am only on my 5th week trying out TinkerCAD for our Logic Circuits course. We are tasked to create a 7-Segment Display Using Logic Gates only. I did all the boolean expressions needed for each segment using K-MAP, and identified the boolean expression needed to create my circuit.
I am doing the segment A circuit and wiring currently but the 7-Segment didn't output anything after simulating. It should have light on Segment A.
Here is the link for my TinkerCAD:
https://www.tinkercad.com/things/jd...e=QOjNbOD_t32_42qIfuNkjnWE0Nt-Yi42CNuwUalVJ_s
How could I solve this? Thanks for those who will help. Please let me know if there is a problem with the link or you need to know more.
Swaysceptile
Joined Oct 28, 2021
17
Your link appears to require membership to access. Please post the schematic on this site.
Hi, I already fixed this problem. I just wanna inquire about another problem that I encountered. The same circuit that I mentioned on my post, but, if I try and simulate it, the 7-segment display is not showing. I'm not sure where the exact problem is because I did all the connections based on my equation. I just can't see where I got it wrong for the output not to work. This one is still for Segment A circuitry. The output should be that the segment A already has light on the 7-Segment.
BTW, sorry for the mess, I am still working on how to wire properly.
dl324
Joined Mar 30, 2015
18,383
Do you have a schematic? I don't trace breadboards unless I suspect that the person in question doesn't know how to wire properly.
You shouldn't run wires over/under components or along the pins because we can't trace/determine connectivity.
If you're not required to use that simulator, I'd use something that simulated from a schematic:
This is from a binary to hex converter I did in DigitalWorks (a free simulator that runs on Windows). It does have some standard components, but I don't use them because schematics using them are difficult to read.
Swaysceptile
Joined Oct 28, 2021
17
Hi, sorry but I directly used the equation itself and made the wirings on breadboard and didn't do a schematic anymore. I'm hoping you could take a look at the link itself if it's okay, and see the problem. I'll try to fix the wires later. I just want someone to take a look and see where might the problem be (if it's okay). Thanks.
Swaysceptile
Joined Oct 28, 2021
17
There seems to be no limiting resistor from "driver-"/logic- ic to the 7-seg. LCD indicator
I tried adding a 1k Resistor from the output to the A pin of the 7-segment but it doesn't seem to work. Would you mind taking a quick look to see where the problem might be?
ci139
Joined Jul 11, 2016
2,000
GFRAB // 7seg pinnout can be swapped in between Com-AN / Com-CA
EDRCG // i a bit cleaned up the ckt - but i didn't checked it's functionality yet . . .
ci139
Joined Jul 11, 2016
2,000
i changed it to a common cathode as you had the Comm connected to neg supply rail - it did lit up the segment A but it didn't respond to any alteration of the toggle button states ??? sorry . . . though i didn't run through all the 16 combinations . . . = i might've missed something
? are you trying to build the 4-bit to 7-seg hex coder < such will be quite complex . . . should put the schematic diagram on paper before attempting to tile it up on pin-boards
random about https://www.dcity.org/portfolio/i2c-7-segment-led-library/ + a ROM version of the thingy https://www.futurlec.com/Datasheet/Motorola/MC14495.pdf
Swaysceptile
Joined Oct 28, 2021
17
Actually I'm only trying to make a 7-segment display using only logic ics and not with the actual decoder
ericgibbs
Joined Jan 29, 2010
21,464
Hi Sway,
That is not an easy task, this image of a decoder shows the complexity of the logic using Gates.
It could be simplified a little by dropping Blanking and Lamp testing section.
Post your version of the decoder.
E
ci139
Joined Jul 11, 2016
2,000
One way to control each segment separately is to use a bit-mask
--e.g.-- the 7 switches (1 for each) or a register/buffer of 7-bits . . .
for encoder or decoder - depending how you call it :
a0:aF = 10110 11111 101011 goes for
DCBA
0000
0111
1000
1111
as
\(\begin{array}{|c|c|c|c|c|c|}\hline {} & B & B & \overline{B} & \overline{B} & {}\\
\hline D & 1 & 1 & 0 & 1 & C\\
\hline D & 0 & 1 & 1 & 1 & \overline{C}\\
\hline \overline{D} & 1 & 1 & 1 & 0 & C\\
\hline \overline{D} & 1 & 1 & 0 & 1 & \overline{C}\\
\hline {} & A & \overline{A} & A & \overline{A} & {}\\ \hline\end{array}\)
\(a=\overline{A}\left({B+\overline{C}+D}\right)+B\left({C+\overline{D}}\right)+AC\overline{D}+\overline{B}\ \overline{C}D\)
and obviously also
\(a=\overline{A\overline{B}\left({CD+\overline{C}\ \overline{D}}\right)+AD\left({B\oplus C}\right)+\overline{B}\ \overline{D}\left({A\oplus C}\right)}\)
the seg. a(0...F) may be optimized for the logical gates you'll use to implement it
