This isn't homework; I'm just trying to teach myself electronics by doing step by step project. ( at http://forum.allaboutcircuits.com/showthread.php?t=40633 )
My goal on this step is to use 3 9v batteries to power two circuits, and regulate the voltage of one circuit to 9v. After learning about different V-regulator approaches, it seems the simplest is just to put resistors in series to make a voltage divider.
The drawback appears to be current related because the resistance and current draw of the driven circuit need to be known in order to choose my 2 resistors properly.
However, in my application I will have a 2.64mA current limiting diode right by the battery.
Because I know the 2.64mA spec, would it be appropriate to use a voltage divider for this circuit? or is there a better method to use in this case?
thanks,
-masked
thanks,
-masked
