Mike, the distortion we are talking about is not clipping distortion. When your battery voltage drops then you must turn down the volume to avoid clipping distortion.I've heard I'm pretty sure worse than 5% distortion from my amp when the battery level was dropping.
I take it as a factor in my whole design because to me it determines how long a battery can live. It seems what affects the output amplitude the most are the resistors connected to the base of the NPN transistors.
With an 8v supply, two transistors are in series on each side of the bridge. Then 800mA x 4V (half of 8V)= 3.2W. Each transistor heats with 3.2W so four transistors heat with 12.8W.If I'm not mistaken, would an idle output current of 100mA with 8V supply make the TIP4x transistors stay cool to the touch? I mean my math leads me to 800mW and double that is 1.6W which is under 2W, then again someone mentioned some specs (particularly with wattage handling) were for marketing purposes?
speakers work from ACI thought speakers were rated in watts. I don't think 100mA would wreck my speaker especially when my supply voltage at worst case right now is 8, and I already tried the speakers in the frying transistor circuit. and to this day the speakers by themselves continue to work because I made an older amplifier design that really distorts at the 5-6V range using the same speakers. The speakers are rated for 20W and I'm sure I posted a picture or link to them on this site before. (each one was about $13 each from digikey)
How did you get 800mA? Was that a value you picked based on the peak current of an earlier simulation when music was playing?With an 8v supply, two transistors are in series on each side of the bridge. Then 800mA x 4V (half of 8V)= 3.2W. Each transistor heats with 3.2W so four transistors heat with 12.8W.
My simulation of your today's circuit shows the "b" amplifer has too much gain. Changing R5 from 39k to 56k fixed it.
You said 800mA in post #136 but did not say if it is idle current or momentary peak current.How did you get 800mA? Was that a value you picked based on the peak current of an earlier simulation when music was playing?
Also, I don't understand the benefit of making R5 56k instead of 39K because when I make it a high value then the output at B looks like its half of output A at best and wouldn't that make the speaker work funny because one end would partly push (because of lower voltage) while the other end completely pulls or vice-versa (because of higher voltage)?
Ok, so a bigger waveform on one output and a smaller waveform on the other output I guess can reduce peak current consumption but wouldn't that make the overall volume of sound lower?With a 7.2V supply and a 7.2 ohm speaker, if one side of the bridge goes to +6.8V and the other side goes to +1V then the momentary total peak voltage is 5.8V and the momentary peak current is 5.8V/7.2 ohms= 806mA.
Yes. On a bridged amplified each side must swings the same amount but inverted. Never mind the peak positive voltages because the bootstrapping allows it to almost be reach the supply voltage. The negative-going swing does not go down to ground, instead it goes only as low as +1V.Ok, so a bigger waveform on one output and a smaller waveform on the other output I guess can reduce peak current consumption but wouldn't that make the overall volume of sound lower?
The datasheets show that a 1N4007 has a forward voltage at a certain current much lower than a little 1N914 or 1N4148.IF those came from me i was just hacking around .. the 4007 are a bad idea .. You should ponder diodes with a lower turn on not a larger ..
you lost me at the 1.41W.Amplifier power is measured in continuous RMS voltage and current. When the signal is a sinewave then a simple calculation converts the peak to RMS.
Your input signal is too low, turn it up to clipping then down a little to eliminate the clipping.
Now the output voltage swing is 6.5V to 2V which is 4.5Vp-p. Only 1.41W bridged into 7.2 ...
| Thread starter | Similar threads | Forum | Replies | Date |
Fuse bridged with wire on cheap electrical goods ? | General Electronics Chat | 10 |
| Similar threads |
