I have a 2432A scope which works fine but has a slightly noise trace (the readout text is fine), see photo. Any hint where I have to start lokking to repair this?
I just changed all the caps on the power supply and main board to yield some nice crisp lines on a Tek 2430A. Usually all it takes. Make sure the cap voltages and capacitances are correct.I have a 2432A scope which works fine but has a slightly noise trace (the readout text is fine), see photo. Any hint where I have to start lokking to repair this?
What do the traces look like if you short the vertical input connectors?I have a 2432A scope which works fine but has a slightly noise trace (the readout text is fine), see photo. Any hint where I have to start lokking to repair this?
Look the same.What do the traces look like if you short the vertical input connectors?
Look the same.What does the traces look like with the inputs shorted to ground?
My old 2432 (now dead with a PS problem) was always noisy.I have a 2432A scope which works fine but has a slightly noise trace (the readout text is fine), see photo. Any hint where I have to start lokking to repair this?
It's the same.What do the traces look like if you short the vertical input connectors?
Looks quite similar, but the traces should be a lot more crisp I think.My old 2432 (now dead with a PS problem) was always noisy.
https://forum.allaboutcircuits.com/threads/tek-2432-nvram-replacement.165205/#post-1454665
Service manual.
https://w140.com/tekwiki/images/e/e4/070-6285-00.pdf
Looks the same.What do the traces look like if you short the vertical input connectors?
Sure, but it's an old scope, they get wrinkles too. The old CCD (Fast In, Slow Out) devices that act as a analog signal sampling buffer in the ADC stage are aging.Looks quite similar, but the traces should be a lot more crisp I think.
My scope has 4400 hours running time, that's not much I suppose.If I remember right, these scopes show the number of hours used in their lifetime. Check yours. It may be tens-of-thousands if in a lab and it was turned on every morning to warm up in case it was needed. Mine had very few hours and spent its life with the dust cover on it on a shelf. Total hours is under 1000. It's either my 2440 or my 2465 that shows hours (or both?).
I think it is pretty low. Your caps may be old or that scope may just be a little noisy.My scope has 4400 hours running time, that's not much I suppose.
| Thread starter | Similar threads | Forum | Replies | Date |
| W | TEKTRONIX 2235 100mhz Oscilloscope | Test & Measurement | 13 | |
Tektronixs Scopes Recapping & Memory | Test & Measurement | 18 |
