Tcd and Tpd in theory
Elad Joel Karas
Joined Mar 10, 2017
I have a question.
Let's say I have 1 buffer connected to a clock, T(High)=10ns, T(Low)= 5ns .
Suppose I can control Tpd. What will happen if I set a long Tpd lets say 40ns?
Will the buffer ignore the clock and get stuck on initial value?
thank you!
Papabravo
Joined Feb 24, 2006
22,111
I have a question.
thank you!
Not necessarily. It is likely that the waveform will go through the buffer with the 40 ns of delay, and will be faithfully reproduced at the output with that delay. A typical opto-isolator has a relatively high maximum frequency, but a somewhat longer propagation delay than you would expect.
http://pdf.datasheetcatalog.com/datasheet/fairchild/6N136.pdf
Notice the claim that it can pass signals at 1 MHz., but the prop delay can be up to 2μsec maximum. finding an opto with a low propagation delay on the order of 40 nsec. is actually quite a challenge.
