Help designing an FM Radio receiver while understanding it's theory.
HussainMaitham
Joined Sep 24, 2024
(Sorry my English may be a bit bad)
Hi :3, I wanted to make an FM receiver circuit, and its my nature that I don't like making a circuit without understanding how it works, plus how do I even recalculate it's values (since I'm using different components), and on my search I have come across two circuits, the first being a two transistor design with tuning circuit whose output is connected to an op amp (this one https://www.electroschematics.com/tiny-fm-radio/) and it is the most common out of them all, tho I won't build it and that's because, first, I don't think I can use a 2n2222 transistor for this because it needs some form of asymmetry as far as I have heard and second of all I heard that this circuit in question is bad and sometimes act as a transmitter and sometimes also hear AM stations and is very noisy, so I moved away, but the second of all and the one I wanted to use instead uses a single transistor in a common base configuration to amplify the RF signal that is being tuned from it's LC circuit on the collecter side while using slope detection ( the only video I found explaining it
) and it seems better in terms of quality and I seen multiple forms of this circuit also online (some being regenerative circuits) but they all uses the same configuration but I have both don't (kinda) don't understand how it works and how to calculate it's values since I want to use a 2n2222 for it and I want to change the antenna, but I still understand how to calculate some values with kind of theory behind its operation so let's start:-
1- The first component and most simple is the antenna, as far as I have researched the most commonly used antenna for FM radio is the whip antenna and I have chosed it for it's simple construction and specifically the quarter wave, I have chosed quarter wave cuz it's already long (won't bore you with the calculations but I came out 75cm for 88 to 108Mhz)
So now comes the first problem and it's the wire sagging as no matter how thick the wire is it always sags just a little (not entirely laying on the ground just the tip touching the ground and the wire forming a bowl shaped almost just almost like a loop antenna) altho I have asked chat gpt and it said it's not as big as a deal but I still want to make sure that this isn't a problem, the second thing I wanted to make sure is the construction, Wikipedia says it's just a piece of wire over a ground plane, so I was thinking is me connecting a wire to a perfboard truly a whip? If let's say this was true then I will be able to calculate it's impeadence, and I first using a whip antenna online calculator but the weird thing is that the capacitance and inductance came out negative which is impossible ( I inputted 75 cm and 0.6mm wire) so the I asked chat gpt and they calculated the following values ( here are the formulas)
Antenna inductance : L ≈ (2 * length) * (log(2 * length / radius) - 1)
Antenna capacitance : C ≈ 1.414 * length / log(2 * height / radius)
So I told chat gpt to calculate them as 75 cm wire and 0.6mm diameter and they came out as
Antenna inductance = 0.14uH
Antenna Capacitance = 10.24pF
And with these values I was able to calculate the reactance and then the impeadence of the antenna of which came out nearly 67 ohms, and by searching google the average quarter wave whip impeadence is 50 ohm which I guess is close enough, but still wondering if those equations of mine were right but from now on I will estimate the value to be 50ohm but I still want you guys to confirm if it was true or not
2-second thing is the transistor portion of the circuit, and I'm going to ignore the 30pF capacitor connected to the antenna for now as I will come back to it later, now on the transistor side I see that the circuit is multifunctional as it both acts as an RF amplifier, a tuner circuit, and a demodulate, as far as I understand or see this circuit is using slope detection to demodulate the original audio wave and then send it back to an audio amplifier (on my case it is an op amp circuit) and the transistor is configurated as a common base amplifier (correct me if I was wrong) now on the circuit he uses an S9018 transistor which is a very good transistor for this application (fte of 1100mhz which comes out as a nearly a gain of 11 beta at 100Mhz) unfortunately for me I don't have it but I do have a 2n2222, and for that I kinda nead to recalculate both for the sake of it working and for me liking to know how the values were calculated, starting with the tuning circuit and the most simple and their frequency is basically
F = 1/2*π*√L•C
This equation tho is not that accurate because I have to take into account the feedback capacitor (30pF one) and the transistor itself capacitance, altho the circuit can take some offset as I'm using variable capacitor for it and anything like 100nH and 27pF should work just fine, but now for the circuit operating point, I was told by chat gpt to experiment with it and suggested I start with 1mA and then for values like 3-5mA later on, but since I'm using a 2n2222 which has a low frequency (300mhz which is a gain of 3 at 100 mhz) this is still acceptable but I want to use 3mA just so I can compensate for the transistor low gain and I dont want the transistor to have a lot of power loss, so assuming a 3mA current operation point I can come up the bias resistor values for the emitter resistor and the base resistors, now for the emitter I can chose whatever I want tho I have to take in mind that this value will also change the impeadence, so let's assume a 330 ohm resistor on the emitter (idk if this is too low correct me if it was bad) and yes I know the guy on the video suggested a 1k pot on the emitter but let's just assume for now since I want more current than him due to my transistor low gain, and with 3mA current that comes out as a voltage drop of 660mV, and with my transistor voltage drop in mind we get around 1.32V on the transistor base, and for the base current we know that I need 3mA flowing and with a gain of 3 that means we need around 1mA on the base, and with those values on mind we can calculate the bias resistors , and since I'm using a 3 volt power supply we can calculate R1 to make sure it can supply enough current and using ohms law I know that this is around 3k ohm and since we need 1.32V on the base and R1 is 3k that means I need around 2k for R2 ( again correct me if I was wrong) and with that we finished all the bias resistors including the emitter one
3- now one values I didn't know how to calculate is how much should the feedback capacitor should be, the original circuit owner says it is 30pF so I'm going with that but If anyone knows how to calculate it I would appreciate it
4- now for what I assume is a low pass filter, circuit owner says that the emitter inductor should be wound on a ferrite core with a value of 10uH, that and with the 330nF forms a low pass filter for around 50Khz which is close for the audio 20Khz and I'm assuming that this is for the noise that may come with the circuit and things like AM stations or anything but I still don't know how it kinda works but I'm going to leave the values as they are.
3- now for the last thing after all is the 30pF capacitor connected to the antenna and the amplifier input, now I'm assuming that this fulfills two functions , one is that it blocks the DC current for the bias resistor to enter the antenna, and second that this is used for impedance matching, now I mentioned in the beginning that the impeadence of my antenna is ~50 ohms, And If I want maximum power transfer I need to make sure that the antenna and the amplifier are impeadence matched, not all I have to know is the impeadence of my common base amplifier and Google says that this type of configuration has a low Input impeadence of 30-300 ohm, now I don't know how to calculate this values so I asked chat gpt and they told me that to calculate the input impeadence of a common base amplifier I need to divide my emitter resistor (330 ohm) by my gain( which at 100mhz is 3) which comes out as 110ohm input impeadence (please correct me if I was wrong in here) so now we have 50ohm antenna and 110 input impeadence, to match them we need to know how much reactance we need and it can be found by by subtracting the amplifier input impeadence by the antenna impeadence which comes out as 60 ohm that means we need a capacitor of a reactance of 60 ohm and at 100mhz chat gpt told me that we need ~26pF which is extremely close to the original value so I'm just going to use 30pF, but again I being you to tell me if my values were wrong
No we have got the calculations out the way I still want to know how the theory behind the operation of this circuit work I mean I know slope detection and I'm assuming that the tuning circuit is offset to get the original value but I'm not sure about the feedback capacitor and the chocke inductor on the emitter, and please tell me if this circuit is going to work for an 2n2222 transistor
And most importantly correct me if I was wrong in any equationz
And thanks you all :3
sparky 1
Joined Nov 3, 2018
1,218
Building a Coax antenna, making it as resonant as possible, cutting wires to exact lengths will improve receiving strength.
96.86MHz is total length 5 feet - .936 inches. It is a 1/2 wave 1.547 M is approx 3 Meter band
Link to Coax and other antenna software Antenna, VE3SQB Ham radio antenna design software programs and sstv,qha, amateur radio,sstv,antennas,j-pole,quad,dipole,discone,antenna program, super scanner, pdl, omni, rhcp, bazooka, coaxial dipole,skyhopper)
If you have an FM radio and a wire FM antenna, tune to a somewhat weak signal, a strong signal is not as good, it is a way to test your work.
The change in volume is good indicator of signal strength. A single transistor needs a very precise circuit, it is not easy at first.
Connect the wire antenna to the radio's antenna, with and without the wire antenna, listening for an increase in volume.
Next build a simple pre-amplifier and connect it between the wire antenna and radio.
When the transistor is biased correctly and optimized for gain the volume will be increased even more.
We use LTspice to run a working simulation and we often use the values from the simulation to check our calculations.
Next insert the adjustable tank circuit (stretch the coil slightly) locate before the preamplifier then later find a high gain RF transistor.
An RLC parallel resonance calculator using values 0.01-3 Ohm, 100nH, 27pF = 96.86 MHz note that as R increases Q decreases.
RLC Circuit Calculator (calctool.org)
note the standard model and visual manual. (epoxy holds up better than super glue, rough up with sandpaper glue the 5 pads as shown)
How to build the simplest transmitter? (translocal.jp)
A battery powered 5V supply, has a power switch and led on/off indicator. Also modifying it with an adjustable LM317 will add usefulness.
As mentioned, the simulator, a voltage source and a resonant antenna are fairly standard for building an RF project.
Build the best antenna you can, adjusting the capacitor to peak voltage will give you much better numbers for your impedance calculation.
28,600
There are many published articles on regenerative receivers, in print format. And there is a whole lot of useless garbage online. Look in some of the older publications by the ARRL. Many of the articles go deeply into how the circuits function.
And for those folks who choose to be critical of my evaluation, I suggest that you actually investigate and locate articles that are technically correct, and not fakes, and post those links for the TS.
