Need Help Designing Power Management Circuit for Production-Ready 2G GPS Tracker (SIM800L + ESP32-C3)
muhammadanas25
Joined Jun 21, 2023
21
Hello everyone,
I’m working on designing a production-ready 2G GPS tracker and would really appreciate guidance from experienced members, especially regarding power management and GPS module selection.
Project Overview
I am using:
  • ESP32-C3 Mini (main controller)
  • SIM800L (GSM/GPRS communication)
  • Planning to add a high-sensitivity GPS module
Requirements
  1. Fast GPS Fix & High Sensitivity
    • I need a GPS module that can acquire coordinates even with weak signals (urban areas, indoors near windows).
    • Looking for recommendations with fast TTFF (Time To First Fix) and good sensitivity.
  2. Wide Input Power Range
    • Input voltage: 9V to 72V DC (vehicle battery compatibility)
    • Need a reliable power management circuit that:
      • Steps down voltage efficiently
      • Handles automotive noise/spikes
  3. Backup Battery System
    • When main power is present:
      • Device should operate normally
      • Backup battery should charge automatically
    • When main power is removed:
      • System should seamlessly switch to battery
    • Also want battery tamper detection
  4. Ignition Detection
    • Detect vehicle ignition ON/OFF (ACC line)
    • Should be safely interfaced with MCU
  5. Remote Engine Cut-Off
    • Ability to control a relay remotely via GSM
    • Needs safe and reliable circuit design
❓ What I Need Help With
  • Recommended GPS module (high sensitivity + fast fix)
  • Complete or reference power management circuit design:
    • 9V–72V input → regulated outputs (ESP32, SIM800L, GPS)
    • Battery charging + automatic switchover
  • Suggested backup battery type (Li-ion, LiPo, etc.) and capacity
  • Best practices for:
    • Automotive protection (TVS diodes, filtering, etc.)
    • SIM800L power stability (handling current spikes)
    • Ignition sensing and relay control
Notes
I am relatively new to hardware design, but I want to build this as a robust, production-level device, not just a prototype. Any schematics, reference designs, or guidance would be extremely helpful.
Thanks in advance for your support!
Irving
Joined Jan 30, 2016
5,195
You are asking a lot. I could give you all the guidance you need up front, but then I'd be doing my paying clients a disservice. I'm happy to provide input, just like the many 100s of professionals on this site who give 1000's man-hours of support to hobbyists and other professionals but the overriding rule, IMHO, is this: You do the work, the research & the planning, then you put your work up for critique and input. You don't get 1000's of man-hours of experience free of effort by yourself.
So, here's my one free piece of input: When all major UK, EU and world networks have announced closure of their 2G & 3G networks, why are you suggesting using 2G?
https://streetwave.co/mobile-networks/2g-switch-off-by-country-guide/
