synchronous 3 bit counter
anhnha
Joined Apr 19, 2012
904
Why have you let so many inputs floating?
I try the asynchronous with these pins floating and had no problem. So I didn't connect these pins to ground.
P.S: I've just tried to connect unused pins to ground but the same problem.
32,840
Just connecting unused pins to ground may not do what you want. What happens with an AND gate when any pin is connected to ground?
What are the pins on the side of the logic gates for?
sailorjoe
Joined Jun 4, 2013
365
Anhnha, your clock is correct, but the interconnects among the flip flops are a mess.
Think about how A2 needs to know the state of A1 to do its job right. See if that helps.
Oh, and don't ground those unused inputs, that would be bad. Think pull-ups.
32,840
What method did you use to design this? Why isn't the output of A1 connected to any other flip-flop but A1?
Probably because it's the msb. Note that the lsb is free-running and the other two either hold their value or toggle based on the lower order bits. A2 is set to toggle with A3 is HI (meaning it will go HI to LO on the next clock) and A1 is set to toggle when both A2 and A3 are HI (meaning they will both goes from HI to LO on the next clock).
32,840
Why does A2 need to know the sate of A1?
Look at the circuit and see which FF is the lsb and which FF is the msb. Of course, it sure would have been nice for Anhnha to label his schematic so that other people aren't having to guess what was meant -- something that they really should have learned by now given how many times it has been pointed out to them.
So you would put a pull-up on the unused pins of an XOR or on the PRE/CLR inputs of a FF?
anhnha
Joined Apr 19, 2012
904
Actually before doing this, I read the article below.
http://www.electronicspoint.com/resources/going-digital.19/
However, I noticed that there is no difference where these pins are connected to ground or not.
Here is what the article says:
I tried the one with 5 flip flops but I didn't work. So I just copied the simple one in the site given above to test.
http://www.zeepedia.com/read.php?d_flip-flop_based_implementation_digital_logic_design&b=9&c=32
I thought it is clear enough.
Q3 is the lsb and Q1 is the msb.
32,840
Note that the instructions provides clearly state that unused I/O must be connected to pin 8 and that pin 8 must be connected to the common ground of the circuit. Though this doesn't make any physical sense given that grounding any input on an AND gate should for the output LO regardless of any of the other inputs.
Regardless of what the simulator does or doesn't allow you to get away with, get in the habit of designing your circuits properly so that the same schematic you simulate will work correctly in the real world.
And "thinking something is clear enough" is a pretty common way to regularly ensure that things get garbled in communication. Don't force people -- particularly people that you are asking for free help from -- to reverse engineer your circuits to figure out what you are doing. Have the courtesy to properly comment your schematics.
sailorjoe
Joined Jun 4, 2013
365
I should have looked at the circuit a bit longer, because I did, in fact, reverse the flip flops. Thanks for pointing out that the LSB is on the right. Things look much better now!
No, my reference to pull-ups was just for the unused pins on the flip flops, the preset and clear lines.
32,840
So how does a FF behave if you put pullups on the PRE and CLR inputs? Note that (at least as indicated by the symbol) these two inputs are active-HI.
anhnha
Joined Apr 19, 2012
904
I tried to include all necessary info just missed that one.
sailorjoe
Joined Jun 4, 2013
365
Aaaaak! I saw the little circles and thought that meant active low inputs. Best if I get out this thread.
hp1729
Joined Nov 23, 2015
2,304
From someone trying to make sense of SPICE ...
Okay unused inputs and outputs are connected to "Pin 8" and Spice realizes these are simply not used. The 5-input Exclusive-OR/NOR can be many different gates????
How does this simulate operation with real gates?
0 to 1 V logic levels???? What logic family is this?
