I am trying to make a Synchronous 4-bit counter using SR Flip-flop
RDrei9
Joined Feb 20, 2024
9
Question is:
Create a 4-bit Counter using SR Flip-Flops with the sequence 13-11-3-5-9-1-14-7-2-6 and recycles back
I tried to simulate it using Logisim by following my solution but its not working
My solution so far (not working)
dl324
Joined Mar 30, 2015
18,465
The first 3 rows in your truth table have errors:
The next state after 0 isn't 11. After 3, it should be 5, not 11. After 2, it should be 6, not 3.
I really hate it when teachers teach you to label the flip flops backwards. A should always be the LSB (2^0).
From TI.
74*160 decade counter:
BCD to seven segment decoder:
RDrei9
Joined Feb 20, 2024
9
From TI.
They didn't teach us about the LSB, i'll try to work on it based on your given answer. Thank you :). If ever i'll ask a question again.
dl324
Joined Mar 30, 2015
18,465
Yes it is, i think everything is wrong hahaha. I tried to simulate this in logisim and doesnt output these inputs 13-11-3-5-9-1-14-7-2-6
That's because your truth table has a lot of errors. The counts above 9 haven't even been completed.
Don't they teach you to put your truth table is gray code order? That facilitates transferring data to Kmaps without having to think about it much.
EDIT: I waded through your truth table and you only have 1 entry correct (count of 3).
