Symmetric Output Sensors (Help)
Stephanus Kevin
Joined Nov 3, 2023
A sensor works by outputting a voltage of -400mV to +400mV with a impedance of 1M Ohm.
a. Design and simulate a circuit that only uses active components, such as an in the form of an OP-AMP so that the output reads 0V to 5V. Create the circuit in LTspice.
Can anyone help me with this topic? Thank You.
Stephanus Kevin
Joined Nov 3, 2023
No, this circuit can use resistors or capacitors. Then in this circuit apply the following circuits:
- Adder Amplifier Circuit Utilizes an adder circuit for symmetric
- Difference Series
- Non Inverting Amplifier
- Low Pass Filter or High Pass filter circuit
You can't use ANY passive components?
I hope you can help me thanks
WBahn
Joined Mar 31, 2012
33,309
We can help, we can't and won't do it for you.
You need to show YOUR best attempt to get as far as you can. We can then help you see what you might be doing wrong and get it fixed, or give you some guidance to help you get from where you are to a bit further in the right direction.
Having said that, the first thoughts that come to mind are:
Does this mean you MUST apply all of these circuits?
This is an incomplete sentence and so it makes no sense.
- Difference Series
I have no idea what this is.
It's going to be hard to design a low- or high-pass filter when there is no frequency-related information given.
