Stop LEDs from flickering
Tonyr1084
Joined Sep 24, 2015
9,744
Another option would be to go with a constant current source. Let the voltage change as needed. You will always have 20mA (or whatever amperage you design for) running through your LED's. I'd still recommend strings of 3 in series and six sets of 3 series.
djsfantasi
Joined Apr 11, 2010
9,237
Thank you. CHANGES: 5V and no buck converter.View attachment 290189
18 100Ω resistors in parallel has an equivalent resistance of 5.6Ω. The result is supplying 300mA to each LED which is rated at 20mA. 15x more current than they are rated for. You’re lucky if you haven’t destroyed several LEDs. As many people have stated, you need one resistor in series with one LED. Then wire all the resistor/LED pairs in parallel.
If they’re modern LEDs, 100Ω should work (running the LEDs at 6mA). If you want them brighter, try 82Ω resistors (but this runs them at 21mA, a bit more than their assumed 20mA maximum)
WBahn
Joined Mar 31, 2012
32,847
How are you coming up with 300 mA?
The resistors in that circuit play no role in establishing the current in the LEDs (unless they draw so much current that the supply voltage starts sagging). Each LED is being placed directly across the supply output terminals. How much current each is pulling is anyone's guess over a wide range of possible values.
djsfantasi
Joined Apr 11, 2010
9,237
Oops, I misread the drawing. I based my comment on thinking the 18 resistors in parallel were in series with the LEDs. I was wrong.
Rokket2001
Joined Mar 19, 2023
18
The multi-series idea is interesting, but I've prepped for redoing completly in LED parallel, dropping the grouped resistor idea. I'll just put each resistor next to each LED. Thank you all for your help. I feel quite the idiot for thinking I had a great idea, but bass-ackwardsing it.
