- Joined Jul 18, 2013
- 30,888
Have you checked out his web site?, is Mr "The R_B" wrong or i wrong or?
He has not been seen on any sites since 2014 but there is some good stuff there.
https://www.romanblack.com/
Motor is 200 steps/Rev, Native. Ie u can feel the steps.No.
You slowly step the motor and note its rotation angle versus the number of steps.
Should take less than hours.![]()
Cheers.Cheers MHR!Have you checked out his web site?
Like I said he has not been seen on this or any of the other sites he frequents since 2014.To Max Headroom
Just to let U know, Roman Blacks site is dormant, cached. No activity on it for some years. .
yes .. doesnt sound good - he certainly clever.Like I said he has not been seen on this or any of the other sites he frequents since 2014.
Just for future reference you can use PSOC to drag and drop logic ontothanks,
but want to use basic logic at this point. Cant program code, among other issues!
Do you mean VFD's?one thing that i do find puzzling.. When VSD's are used, especially with unshielded cable between the drive & the Induction motor,
Also, Ive not seen heat sinks fitted to steppers, & some are real hot ~80C !! U can imagine what that does to the permanent magnets, bearings etc. A cost thingy?
...Do you mean VFD's?
If so the 3ph inductor between the VFD and motor is to take out the harmonics that may be present, many do not bother to use them.
It does help on both motor and VFD.
When steppers overheat it is usually those that are using higher than the rated current, if this is within the rated plate current there should be no need for concern.
...Just for future reference you can use PSOC to drag and drop logic onto
a gui schematic sheet, and pins, then use wire tool to connect them, and
build the project without writing a single line of code. That of course will
only use 5% of the parts capability, but is a handy way of doing custom
small logic designs.
There are more sophisticated onchip resources, some where you
would only have to write a single line of code, Like "Counter_1_Start();",
and your in business.
Same goes for an OpAmp or Comparator or DAC...., drop onto schematic, wire it to
pins, and write one line of code, the "youropampname_Start();'
I use it for designs, many times of which I use it to create my own test bed
for signals, etc., and sometimes the no code simple logic designs I need.
I did tons of discrete logic designs in 70's, do not want to go back to using whale
oil lamps for light......New GUI tools like this with the hardware on chip so useful
and time saving, save the effort for the big ideas, not how many wires and parts
I can poke into solder less breadboard in a day...ugh.
And along with this accurate V and T generation compared to using discrete
approaches like 555 timer and its passive part cadre of components needed.
Just a thought next time you need to create a low end logic design.
Regards, Dana.
...I know @qtron said he doesn't code, but while looking for something else I saw this and thought of this thread, it may or not apply to what is being done here. http://www.mcmanis.com/chuck/robotics/projects/lab-x3/quadratrak.html
and this, http://www.mcmanis.com/chuck/robotics/projects/encoders/index.html Both of them coming from,
http://www.mcmanis.com/chuck/robotics/projects/index.html
Edit, don't know how everything came up underlined?
Yes, do not jump ship, just store in back of mind. Also w/o investing inMay i assume PSoC stands for programmable system on a chip?
Anyway wont be jumping ships midstream![]()
No, PSOC I/O cannot drive > than its Vdd range, max at 5V logic. However itwith real world logic in can set up any interface to other logic, analogue or machine by simply choosing the appropriate device.
ie, if logic o/p is 0-5v, & machine its driving wants 0-24V, can PSoC do that.
ie, does it have the ability to internally connect logic sections to different supply rails?
A component is an onchip resource. List attached for 5LP family.Turn OFF Unused Components The easiest way to reduce power in Active mode is to turn OFF unused PSoC Creator Components. Any Component that can be disabled in Active or Sleep mode includes a _Stop() function in its API. This function immediately halts all operation of the Component and sets it to its
