STM32H563 Peripheral Saturation – Moving to Multi-MCU (Stepper + DC Load Slaves) – Architecture Review
PraveenBLM
Joined Jan 28, 2026
Hello ST Community,
I am working on a commercial vending machine controller and would like to get feedback from ST engineers and experienced STM32 designers regarding a system architecture change.
Problem Statement
The current single-MCU design is constrained by:
  • Timer availability, particularly for stepper and DC motor control
  • GPIO interrupt count, driven by sensors and safety inputs
  • GPIO pin availability, limiting further expansion
  • Increasing real-time jitter when multiple loads operate simultaneously
These constraints are no longer addressable through software optimization alone and are limiting both scalability and reliability. This has led us to consider a multi-MCU architecture.
Proposed Architecture
Master MCU
  • Device: STM32H563ZIT6
  • Responsibilities:
    • All sensor acquisition (ADC and digital)
    • Control logic and system state machine
    • Recipe execution and sequencing
    • Safety checks and fault handling
    • Communication with UI/HMI
  • The master MCU does not generate direct motor timing signals.
Slave MCUs (2x)
  • Dedicated load-handling controllers
  • One MCU for stepper motor control
  • One MCU for DC motor / PWM-based load control
  • Slave MCUs perform only deterministic actuation
  • No sensor acquisition and no business logic are implemented on slaves
Inter-MCU Communication
  • Primary option: CAN (FDCAN), chosen for arbitration, fault handling, and robustness
  • Secondary option: RS485, considered for lower-priority or legacy expansion
A block-level architecture diagram has been attached for reference.
Points for Discussion
  1. Is this master + load-slave MCU architecture a suitable long-term solution for vending machine or appliance-class products?
  2. From an STM32 architectural perspective, are there recommended design patterns for systems with heavy timer and interrupt usage?
  3. CAN vs RS485 for multi-MCU control:
    • CAN appears preferable for arbitration and fault handling
    • Are there any STM32H5-specific considerations or limitations?
  4. What are the common pitfalls in such systems (boot sequencing, synchronization, fault recovery, debugging) that should be addressed early?
  5. From a product lifetime perspective (8–10 years), does this architecture appear robust and maintainable?
I would appreciate feedback from:
Developers with multi-MCU STM32 designs
Anyone with experience in CAN-based industrial / appliance systems
Thank you in advance for your insights.
Best regards,
Praveen Kumar G,
Boatload Minds Pvt Ltd.
35,299
Welcome to AAC!
Looks like a good plan, in theory. In practice, it comes with its own complications.
I would go back and examine each one of the limitations of a single MCU solution. There are ways of overcoming each limitation.
