KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
I'd like to see at some point: (final tests)
1. Temperature feedback transistor attached to heatsink with thermal glue. Would you order from Farnell uk?
2. Quiescent current vs time. I'm not sure you got 0V or X mV across the emitter resister? Alternatively, set the scope to look at a low signal, at the +- crossover point and look for crossover distortion. Flat at the zero crossing when the amp is cold.
3. 1/2 to 3/4 power 20 min test with temperature of the output transistors.
If you have quiescent current, I think your done unless this thing removes it at idle like Les sort of suspects.
The output transistors SHOULD BE slightly warm idling for 20min to an hour.
