KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
Vave should be close to zero. You probably have a DC offset close to 3.24V.
I do have a fluke thermomiter i could use if that would be any good for measuring the temperatures?Much better. So you got 38.9*38.9/6 or about 250W and the DC offset should measure 80mV or sol
I strapped an AA battery pack to the back of my DSO150. You might want to invest in a wall wart. I forget what the supply restriction is.
Specifications:
So it looks like you could be within specifications.
You do need to look at quiescent current, no load, no signal over time. Look at the voltage across say R64 or R73 over time for about 20-30 minutes. It should stay relatively stable over time, 0V isn't good.
I do think you should get a thermal adhesive for Q29. Not thermal paste. There might be some adhesives that will break ther bond when twisted. Not sure.
Remember, that you use only a really thin film of grease for insulators that require grease. Sill-pads do not require grease.
They are usually a soft grey, compressable and not smoothe. Kapton/Polyimid is orange and does require grease. Mica is an old material.
If you have a way to measure the temperature of the outputs, use it. Don't use the finger test unless you have say a thero-pad between you and your finger. Your looking at 50V.
You could even use the diode mode on your meter and the B-E junction of the transistor. Your interested in relative differences and not calibrated differences. It should be -10mV per deg C. So, you can say, thansistor A is hotter than transistor B by 10 degrees C.
Then do the test again if you can't what you need.
I think the amp has a clip indicator, but don't test it using speakers.
You have to get the repair right before you can push it hard.
Hopefully, you can see the importance of initial troubleshooting without a load and a signal applied.
No load, no signal is a bad place to be.
So when you say 6 base emitter junction drops your refering to the 4v bias collector and emitter voltave on Q29, this ÷6 gives o.6v forward bias for 6 transistors, but there is 4 transistors on the output tails either side, 4+ and 4 --, so the bias should be closer to 5v ? Make any sence at all ?
Look at the manual and pay attention to the focal distance and spot size.I do have a fluke thermomiter i could use if that would be any good for measuring the temperatures?
