yesYou mean there was no reading as if the leads were not even connected?
when it is off it give me a reading with the cable in normal position, now I'll try the reverseTry reversing the leads on the meter.
What do you mean when it is OFF? The board is not connected in the amp correct?when it is off it give me a reading
I got 11.8 volt with the voltmeter on voltswhen it is off it give me a reading with the cable in normal position, now I'll try the reverse
the reverse 11.8 both pin 1-2I got 11.8 volt with the voltmeter on volts
but in diode mode I got nothingon the reverse 11.8 both pins 1-2
no, I do what you telling me, (i think) i just tried in volts modeWhat are you doing?
Did you plug the board back in the amp?
the board is not in the ampno, I do what you telling me, (i think) i just tried in volts mode
if i put the lead to pin 10 and pin 1 than 10 and pin 2 in diode mode it does nothing as I told you, in the reverse is the same with the amp on, if i turn it off I have a reading in diode modethe board is not in the amp
Turn what off? The Amp?if i turn it off
yes with the switch off it give me a reading if i switch on, it is as the lead are not connectedTurn what off? The Amp?
If the board is not in the Amp what does turning the amp ON or OFF have anything to do with your readings?
no my friend is not! I follow your instruction, I did not connect itSo the small board is connected in the amp?
ho gosh! I was reading the connector on the amp j8! apology, I do it nowThis is the board I'm referring to for the readings from pin 9 and 10 to pins 1 and 2.
pin 10 to pin 1, 1.820 pin 10 to pin 2, .555, apology againho gosh! I was reading the connector on the amp j8! apology, I do it now
Ok brother, let me said that I do really really appreciate that you spend your time helping me! I wish I could do something for you, you great! Talk to you soon, I order it now…If is ok, as soon I got it I will install it, and then I contact youOK that makes more sense but does not show a short. Not sure exactly what is going on but suspect the LM13600
We can continue when you get a replacement.
