SR technology jam 150 plus (Schertler) keep burning resistor R2
Cesco77
Joined May 23, 2022
307
Sorry to hear that my friend.
No apology required. We will continue when you are well again. Take all the time you need.
Hi, finally I feel better, still got headache but less then before and I'm testing negative! I have install the components, diode and transistor, not test it as I prefer doing it under your supervisor, when you ready i'm ready...I have 3 hours free now or this evening after 8pm! Or when you can ciao
Cesco77
Joined May 23, 2022
307
Great news!
Did you get a replacement chip for the small board?
No my friend, I realise that was coming from abroad and I cancel the order! Than I get covid and I completely forgot about it! I can buy it, is not a problem, we can procede when I got it
sghioto
Joined Dec 31, 2017
8,765
OK.
Do this without the board connected in the amp.
Connect the negative lead of the meter on pins 9 and 10. Those two pins are connected together and are the ground connection for that board. Set meter for DIODE
Take the positive lead and get readings on pins 1 and pin 2.
Cesco77
Joined May 23, 2022
307
No problem, take all the time you need!!
honestly, I don't know how to thank you
OK.
ok
