SR technology jam 150 plus (Schertler) keep burning resistor R2
sghioto
Joined Dec 31, 2017
8,729
Good. From what you are telling me everything appears to be OK, meaning no shorts. At this juncture normally I would turn the amp ON and see but let's wait until I can continue as I have to leave now.
Cesco77
Joined May 23, 2022
307
Ok bro, thank you for your help much appreciate, I'm wait for you tho! Ciao
sghioto
Joined Dec 31, 2017
8,729
What was the reading on the collector to ground on the 20K scale? You can also read from the metal tab to ground as well.
The metal tab is the collector.
Cesco77
Joined May 23, 2022
307
Sorry I was out as well, I just coming back, the reading are 12.06, on begin it was going up quite fast than it slow down and it "stop" at 12.06, maybe it would still go up a bit but, I do assume it's around that..
Cesco77
Joined May 23, 2022
307
I'm quite scary to do so, I have tried before, and it blow the R2, now a part from checking component, I haven't done anything to it, so I'm quite sure that will happen again! Should I proceed anyway?
sghioto
Joined Dec 31, 2017
8,729
Yes I kinda feel the same.
Do you have any higher value resistors on hand? I'm thinking of substituting R2 with a higher value that will not "explode" when the amp is turned ON if there is still a problem.
Cesco77
Joined May 23, 2022
307
I have 20k resistor, but by doing that is not dangerous for other component on the way?
