SR technology jam 150 plus (Schertler) keep burning resistor R2
sghioto
Joined Dec 31, 2017
8,765
I'm not sure because first you said the relay didn't click right away but now it does so I need to check the voltages again.
I'll tell what to check after you read this
sghioto
Joined Dec 31, 2017
8,765
D2 is a 13 volt zener. The relay will take longer to activate but it might work as a test.
Can you cut D5 out of the circuit and leave enough of the leads to tack solder the D2 type diode so you don't have to remove the board?
