Someone help about transformator
Dzoro
Joined Feb 1, 2019
194
Oh i just discoverd something.I was looking on the fm radio board and noticed two burnt ressistors and they are in series with the output of the two blue wires on the transformer so can that be why the transformer failed?
sghioto
Joined Dec 31, 2017
8,748
Yes i know but i realy want to get it back running beacose is a old thing that it is not produced anymore
It's possible. A power transformer shouldn't be hard to find and the audio chip is still available.
Usually you don't see resistors in series with transformer leads. The resistors could have been underrated for wattage and over time are showing the result. Hard to tell with out schematic. What is connected after the resistors?
EDIT: The resistors may connect to lamps.
SG
Dzoro
Joined Feb 1, 2019
194
SG
I don't know i will need to see
And there are no lamps on the thing and when i hook power to that circuit the resistor is smoking and i mesured the voltage accros and it was 6 volts and i puted 15 vdc on the main input
Tonyr1084
Joined Sep 24, 2015
9,744
Oops. Be careful. The other secondaries (two blues) may have been 5 volts connected to that part of the circuit. Be careful not to over voltage the circuits or you could end up with a pile of scrap on your workbench.
Dzoro
Joined Feb 1, 2019
194
I know but the ressistor was burnt before i hook my 15 vac
