Solar panel current measurement using INA219
zazas321
Joined Nov 29, 2015
936
I have went up to 15 V and the voltage error remained the same voltage error was about 14.85 at 15V which is much better. I guess the problem was just messy connections I had though 80mV error is still remaining unknown
Another problem I have realised is that I might have problems with my voltage regulators. I use 7805 1.5A 25V maximum regulator. But even at 15V , 100mA it got very very hot ( burned my finger to touch) . I cannot Imagine this regulator running my circuit at 20V and 300mA there is no way
ericgibbs
Joined Jan 29, 2010
21,584
hi 321,
I am looking forward to receiving my INA's so that I can run comparative tests.
The long delivery time is a pain.
E
Add an heat sink to the 5V regulator.
zazas321
Joined Nov 29, 2015
936
It could be becuase I have used a brand new breadboard that I have borrowed from my friend. Is it normal for 7805 to get very very got? I would be scared to leave my system running in case it catches fire :D
ericgibbs
Joined Jan 29, 2010
21,584
hi,
The wattage across the 7805 is the voltage drop across the 7805 times the current , so at 20V and 300mA.
15V * 0.3 = 4.5Watts, you must have a good heat sink.
For15V at 100mA , thats 10V *0.1A = 1Watt, the 7805 at 20C ambient is limited to approx 2Watts without an heat sink.
E
hafsa
Joined Jul 19, 2019
Hello. I am working on my project and I need to measure solar panel current. I am able to measure voltage of the solar panel by using potential divider and connecting to analog pin of the arduino and then reading the pin. I also need to measure a current up to 1A and I have found a chip INA219. But i do not know how to properly connect this chip to my system. https://www.adafruit.com/product/904
I want to connect the current sensor to the positive terminal of my solar panel ( high side ) and display the current and voltage readings on my LCD display. Could someone give me some tips? Thanks
MOD: Rotated your image.
please if you know how to connect INA219 to the solar panel share with me
thanks
zazas321
Joined Nov 29, 2015
936
thanks
Could you give a little bit more details about how are you trying to connect things?
Looking at a basic INA219 example above, connect the positive terminal of your solar panel to Vin+ of INA219. Vin- of INA219 is going to your load (whatever you are trying to power off solar panel (battery charger or your load).
