Solar panel current measurement using INA219
zazas321
Joined Nov 29, 2015
936
Hello. I am working on my project and I need to measure solar panel current. I am able to measure voltage of the solar panel by using potential divider and connecting to analog pin of the arduino and then reading the pin. I also need to measure a current up to 1A and I have found a chip INA219. But i do not know how to properly connect this chip to my system. https://www.adafruit.com/product/904
I want to connect the current sensor to the positive terminal of my solar panel ( high side ) and display the current and voltage readings on my LCD display. Could someone give me some tips? Thanks
MOD: Rotated your image.
zazas321
Joined Nov 29, 2015
936
I had a look at INA219 board from adafruit that has a shunt resistor built in already so thats why I am a little bit confused. I have added few pictures that I have managed to get from adafruit website. Lets say i cannot Vcc to positive terminal of my solar panel and GND to negative terminal of my battery, what is Vin+ and Vin- used for then? and where do i connect my output ( voltage regulators) and where do I measure my current?
bertus
Joined Apr 5, 2008
23,006
Did you read this piece on the product page?
It descibes the value and use of the shunt resistor:
A precision amplifier measures the voltage across the 0.1 ohm, 1% sense resistor. Since the amplifier maximum input difference is ±320mV this means it can measure up to ±3.2 Amps. With the internal 12 bit ADC, the resolution at ±3.2A range is 0.8mA. With the internal gain set at the minimum of div8, the max current is ±400mA and the resolution is 0.1mA. Advanced hackers can remove the 0.1 ohm current sense resistor and replace it with their own to change the range (say a 0.01 ohm to measure up 32 Amps with a resolution of 8mA)
Bertus
zazas321
Joined Nov 29, 2015
936
Yes I have read that I will not get anywhere close to 3.2A. My solar panel can reach 0.5-0.6A so 1A is more than enough for me. I could not find any other current sensing chips that would be more suitable
ericgibbs
Joined Jan 29, 2010
21,576
hi,
If I understand you correctly, this is how I would connect it, ref images.
If in doubt please ask.
E
NOTE: Vin [ bottom right] maybe connected on the PCB, if not link as shown in the circuit diagram
bertus
Joined Apr 5, 2008
23,006
When you do not go over 0.8 A , you can reduce the gain of the INA219.
See the datasheet how to change the gain.
Bertus
zazas321
Joined Nov 29, 2015
936
hi,
E
It would be easier for me to understand if you draw on the INA219 adafruit chip instead of INA219 individual chip because the one on adafruit have some additional things added. I am adding one more picture so you can understand what exactly I mean.
In the first picture, according to this website:http://henrysbench.capnfatz.com/hen...urrent-sensor-voltmeter-tutorial-quick-start/ , i should be able to measure the current and voltage of my solar panel. But If i want to further connect voltage regulators to my solar panel , is it correct to connect them like that? ( See second picture).
zazas321
Joined Nov 29, 2015
936
Okay and this is exactly what I am confused about. I am not sure what to do with my LOAD because it is way more complicated than LED. I connect two voltage regulators to my solar panel that further connect to more devices and I do not know where do I connect Vin -. So according to your sketch, instead of led and resistor, I use 5V and 3.3V regulators as my load.
Also, I am a little bit confused why positive terminal of LED leg is connected to Vin- ?
ericgibbs
Joined Jan 29, 2010
21,576
hi,
I would say the printed ident labels on those pins are misleading.
Vin is the connection to the solar panel and -Vin is out to the load.
To measure the current from the solar panel to the load [ on the high side] the current must flow thru that sense resistor.
I have shown the LED from the link circuit to show how the load is connected.
The load can be your voltage regulator inputs or a rechargeable battery etc ...
Look at the Fig 19 I posted you can see the load current drawn by the load from the solar panel flows thru that resistor. OK.
zazas321
Joined Nov 29, 2015
936
Okay, so could I connect my Vin- of current sensing chip as shown in the picture below? It would be probably easier to experiment and test myself. I am currently waiting for my components to arrive. Thank you for your help anyways!
ericgibbs
Joined Jan 29, 2010
21,576
hi 321,
Please post a decent drawing showing more detail on how the solar/INA/ regulators are going to be connected, so that we can be sure its correct.
E
LesJones
Joined Jan 8, 2017
4,544
I have used the same type of INA219 module for monitoring battery charging voltage and current. I Added 3 extra 0.1 ohm resistors in parallel the onboard 0.1 ohm current shunt to get the current range I required. (So my shunt value was now 0.025 ohms.) I use a PIC12F1840 to read the data and convert into readable ASCII text . This is then transmitted to a PC using a pair of HC-12 RF modules. At the moment I just display the results using "Tera Term" terminal emulator program. If it is any help to you I can post the code that runs on the PIC12F1840.
Les.
zazas321
Joined Nov 29, 2015
936
Hey. I have finally received my INA219 chip and I am just trying to do a simple excersise to display the current and voltage of my power supply. I have added pictures and I cannot understand why there is a difference of about 0.1V between my power supply and INA219 reading. I have tried a range of voltages and it seems to increase with increased supply voltage. Does anyone know why is it happening? I am aware that there is 0.1 Ohm resistor on INA219 chip, but with the current flow of 40mA, the voltage drop should be only 4mV . Am I right?
