SMPS Power Unit : Can I replace the Electrolytic Capacitors with SMD Tantalum Caps for secondary ?
MELEZZOR
Joined Jan 23, 2019
6
Hi all,
I am looking at replacing some of the Electrolytic Capacitors on the secondary side of my Panasonic VCR SMPS Power Unit, with all 50 volt Tantalum type. Their Capacitances are 3 nos. of 10uF 50v , 3 nos of 100uF 20v, 47uF 50v & a 680uF 50v... I have already tried on a PC SMPS and it has been working fine for last two years with perfect wave output on Oscilloscope
But this being different in this case as it's a 25 year old VCR PC Power Supply, I need your suggestions on whether it's advisable.
Ian0
Joined Aug 7, 2020
13,310
Don’t.
Tantalums have a nasty habit of blowing up when used as decoupling capacitors.
if they need to be replaced, replace them with electrolytics.
MELEZZOR
Joined Jan 23, 2019
6
Don’t.
Thanks a lot bro....how about using a normal SMD Chip type capacitor? Just asking...
ronsimpson
Joined Oct 7, 2019
4,853
Can I substitute the Electrolytic caps for SMDs,on the Secondary side of the VCR SMPS Unit?
Yes. Some types of capacitors have a problem with voltage verses capacitance. Example at 0V 1uF but at 99% voltage 0.45uF. This is OK just as long as you know what is happening and add more capacitors.
