Single phase induction motor Torque under increased frequency and Same/Constant current.
Stoyan.Nikolov.2Induction
Joined Nov 26, 2023
44
Consider Single phase induction motor.
What will be torque of induction motor, if we increase supply frequency 10 times, if the motor uses same supply current.
Let's say Torque (Supply frequency 50 Hz, Supply current 10 Amperes ) = N
What is Torque (Supply frequency 500 Hz, Supply current 10 Amps) = ?
Will it be 10*N ?
Also what will be the Output Power?
Let's say Power (Supply frequency 50 Hz, Supply current 10 Amperes ) = N
What is Power(Supply frequency 500 Hz, Supply current 10 Amps) = ?
Thank you.
38,953
Consider the power.
Assuming the motor operates normally at 10X frequency, giving 10 times the output RPM, the output torque will be 1/10th for the same current, since torque times RPM determines the power output, and the input power hasn't changed.
Joined Nov 26, 2023
44
Consider the power.
Thank you for your answer.
The motor uses same current for both frequencies.
MaxHeadRoom
Joined Jul 18, 2013
30,890
It would be expected that the resultant Torque will decrease with increase in frequency.
How do you maintain the same current for both ?
LowQCab
Joined Nov 6, 2012
5,102
Watts of Electricity can be converted directly to Horsepower or Kilowatts, and vice-versa.
Torque (Pounds/Feet) X RPM / 5252 = Horsepower
735.5 Watts = 1-Horsepower = 735.5 Watts.
If You put more Watts of Electrical-Power into the Motor,
the Motor will have to dissipate MORE-HEAT !!!!
At some point the Motor will fail because of excessive HEAT.
The Motor is rated at a Horsepower-Level, or Wattage-Level,
( either of which are effectively the same thing ),
that will not exceed the amount of Heat that the Motor can reliably withstand.
If You need high-RPM capability,
use a DC-Motor, or a "Universal-Motor",
NOT a Synchronous-Motor.
schmitt trigger
Joined Jul 12, 2010
2,301
Take this from someone who actually designed and built electrical motors as a real job:
AC INDUCTION motors (not the AC SYNCHRONOUS) are constant V/f ratio devices. If you increase the frequency without increasing the voltage, the rotor slip will increase and the torque will drop like a rock.
You would have to increase the input voltage 10 times, meaning that the applied voltage would be 2.3 kilovolts. The rotor speed would increase roughly 10X
Thus, in addition to the steel core overheating, the bearings overheating, the 10X centrifugal forces pulling the rotor apart, you would also have to deal with the insulation arcing all over the place.
I don’t think your interest is purely academic, as you have stated somewhere else. What exactly are you planning to do?
