Single phase induction motor amps
Autobike
Joined Feb 23, 2018
110
Hi :) recently i did a bearing replacement of a single phase induction motor which was manufactured in 1990s. below specs were printed on its nameplate.
HP : 0.75
Voltage : 230V
Amps : 4A
is 4A the maximum current drawn by motor when it's working ? thank you
Ian0
Joined Aug 7, 2020
13,288
HP : 0.75
Voltage : 230V
Amps : 4A
Yes. Its startup current will be more than that.
JohnSan
Joined Sep 15, 2018
139
The startup current may be 10 x the rated current for a short time (few seconds) on an ac induction motor, depending on the starting method..
The running current in unloaded condition (just a spinning shaft for example) for a small motor is usually around 35 to 40% of rated current.
So for a 4A rated motor will be around 1.5amps.
As the motor load is increased, (coupled to a pump, or a fan blowing air for example) the current will rise.
The load on it should not be increased any more, when the current reaches 4 amps.
If the load continues to increase, the current will continue to increase above 4 amps, but the motor is then in an overload condition.
Small motors can typically cope with short term 25% overloads at rated speed with no problems.
