Sine wave generator with variable frequency (1Hz-500kHz)
Status
Not open for further replies.
Papabravo
Joined Feb 24, 2006
22,102
Oscillator: "AD9850 signal generator module. "
osc
Amplifier: 500 volts peak = 1000 volts p-p = 1200 volt supply.
This transistor has no speed rating and may be slow. It is only 1200V. There are not many HV transistors in production now.
STN0214
Here is another but I know it is too slow.
STP03D200
I have some old stock 2kv transistors that are not available from suppliers. I think we got 100khz and 300V out of them.
MOSFETS: HV and low current. mosfet Here is an example of a part.
500v ac 500khz will burn. It will peal the skin off your finger. I have seen and had burns from this. It is very dangerous. At that frequency you do not have to have one hand on ground to get hurt. If some one is going to build this it needs current limit!
I have a bad feeling about this. It actually sounds like a device to wring confessions out of prisoners. I don't care for the evasive answers either.
sghioto
Joined Dec 31, 2017
8,729
and if you don't mind something that's obsolete
IanO you crack me up. :rolleyes: Why is it when I suggest a component that is discontinued or "obsolete" in your opinion it's a mediocre design but if you suggest one it's OK? Maybe because it gets the job done?
SG
Ian0
Joined Aug 7, 2020
13,210
I suggested one component that was in current production, and one that is obsolete but still available, and cheaper. That way, whoever is designing it can choose. It depends a lot, as I learned from the previous topic (probably from you), whether it is intended to make a single unit, or a production run. My mindset is normally to design something that can be built 50, 100 or 1000 times without supply problems. There may be other people who are happy to build one with no intention of ever building another.
Ian0
Joined Aug 7, 2020
13,210
And if it's in a push-pull circuit, or inductively loaded it can swing to almost double that. There's another parameter called Va(0) - the anode voltage with no current flowing - which is 2kV
Status
