Simulating a RF transmitter bug in LTspice
ericgibbs
Joined Jan 29, 2010
21,637
hi 2k4.
In theory the RF amplitude should be constant and only the frequency change with FM modulation, but I would expect with such a simple transmitter the amplitude will also vary.
Have you seen this link.?
E
https://www.talkingelectronics.com/projects/Voyager/Voyager-P1.html
clip:
The stage is also said to be "self-biased" with the 1M base resistor turning the transistor on until the collector voltage drops to about half rail voltage. The value of the base resistor is chosen so that this occurs.
The value can be chosen by experimentation. If the value is too low, the voltage on the collector will be below half rail. If it is too high, the collector voltage will be too high. The AC gain of the stage is about 70 and the signal is amplified and passed to the oscillator stage via a 100n capacitor.
The signal is now typically 200mV to 2,000mV in amplitude and this is adequate for injection into the oscillator stage.
Dinesh_2k4
Joined Aug 18, 2022
32
hi 2k4.
E
clip:
I checked it out bro
and also found that the parasitic cap between base and collector changes with respect to the amplified message signal inducing a change in the oscillating frequncy
In an actual hardware implementation this happens but in simulation the parasitic capacitances are modelled constant.
but is there anyway to model such a small parameter?
ericgibbs
Joined Jan 29, 2010
21,637
Check the voltages on Vc1 and Vb2, as Vc1 rises Vb2 falls, eventually cutting off Q2 transistor.
The problem is partly due to the long time constant of the 22N and 1Meg resistor.
E
Upgraded plot to show Vc and Va, Vo.
Alec_t
Joined Sep 17, 2013
15,163
The LTspice model of the BC547B (and C) does indeed model the base-collector capacitance variation with the reverse bias voltage. Here's my test rig for that:
Dinesh_2k4
Joined Aug 18, 2022
32
hi 2k4
I can get the oscillator to start up, providing I delay the modulation.
Any initial modulation seems to block the oscillator from starting up.
The simulation takes minutes to run,
E
Is there any way that i can simulate this circuit without any much change in the amplitude of the o/p waveform (without changing Input signal)?
Kindly help bro
Dinesh_2k4
Joined Aug 18, 2022
32
Hi 2k4,
Are you not able to simulate the circuit, I am not sure what you are asking me to do?:(
E
I m able to simulate
Im getting amplitude variations in my output,which is not desired in FM
I showed simulation results to ,my facultybut they are not accepting
I am now doubting if it is really possible to make this circuit work using hardware components for my college project
ericgibbs
Joined Jan 29, 2010
21,637
Hi 2k$,
I have tried a number of circuit idea's but with such a basic oscillator circuit the way the modulation is applied, we will always get some amplitude modulation.
E
Dinesh_2k4
Joined Aug 18, 2022
32
Hi 2k$,
E
I can understand
Is it guarenteed to work if i implement this ckt using hardware?
if not,Is there any simple alternative circuits that does the same( a FM transmitter with mic.).
I dont have much experience, Im not clear on this.
