Simulating a RF transmitter bug in LTspice
Dinesh_2k4
Joined Aug 18, 2022
32
hey guys i,m new to this forum and Lt spice
I am planning on building a FM bug using hardware,
i am trying to simulate this circuit using LTspice
In simulation i am replacing the microphone with a voltage source of 10mV and 2kHz then removing 68k resistor.
simulation file is attched.Kindly assist me with this guys..
I get the amplified version of signal from the first stage but the oscillations of around 88-108MHz are not being produced from the second transistor
Dinesh_2k4
Joined Aug 18, 2022
32
Thanks a lot!!! ericcgibbs
its working fine right now
I was planning on using a BC547to build the circuit and when i changed the 2N2222 to BC547B its still working fine!!
I have a doubt the output voltage is around 16-18 while the supply is just 9V is it normal? (just due to capacitors) can u plese explain
Dinesh_2k4
Joined Aug 18, 2022
32
Thanks bro I have installed the MIC library too!!
what are theparameters in that mic module?
frec indicates frequency
what does "dbSPL" indicate?
check this out:
ericgibbs
Joined Jan 29, 2010
21,637
Hi 2k4,
I cannot make it run correctly, sometimes it will, but it takes ages.
I suggest you test with the 1kHz voltage source and not the mic.
E
ericgibbs
Joined Jan 29, 2010
21,637
hi 2k4,
Those voltages shown on the original circuit are incorrect, so that makes me suspect that there are other errors in that diagram.
E
ericgibbs
Joined Jan 29, 2010
21,637
hi 2k4
I can get the oscillator to start up, providing I delay the modulation.
Any initial modulation seems to block the oscillator from starting up.
The simulation takes minutes to run,
E
