Simple Bench Power Supply 10A
ortiko
Joined Oct 21, 2014
66
ScottWang
Joined Aug 23, 2012
7,505
If you using this circuit, the power transistor are 2N3055, for the power consumption issue, so you better using 4 pcs of 2n3055, at least 3 pcs, and each 2n3055 needs to in series with a 0.2Ω/10W resistor.
ortiko
Joined Oct 21, 2014
66
No images...? Sorry
Maybe a moderator can erase the above post please
After a conversation I had with colleague Andreas about it...
To be continued...
ortiko
Joined Oct 21, 2014
66
I have replaced the 2n3055 with MJ15003
It is far better as i know
ortiko
Joined Oct 21, 2014
66
And the resaults are very good !!!
polishing :)
Electroprojects
Drilling it...
Holes readyto insert parts
ortiko
Joined Oct 21, 2014
66
Something i haven't done yet and must be done is to make the Transformer from 30-0-30 8A to 0-30 8A
Need to parallel the secondary so i can drain all amperage from 0-30
Any suggestions will be appreciated.
R!f@@
Joined Apr 2, 2009
10,010
U can if you can isolate the center tap.
CT secondary are connected as follows.
30-0-30 --> Start A(30V)-End A joined with start B (0V)-End B (30V).
A and B are two secondary windings.
Disconnect End A and Start B ( which is Center tap )
Connect Start A and Start B together
Connect End A and End B together.
After you disconnect center tap you will have isolated secondary A and B windings. You will get 30VAC on each windings.
After paralleling them if you measure 30VAC on the secondary winding you are good to go.
Mind you if one winding can handle 8A you can draw max of 16Amps by paralleling them
R!f@@
Joined Apr 2, 2009
10,010
By the way for huge currents, the smoothing cap needs to be 10,000uf or more.
And the Power should be taken directly from the capacitor terminals.
Not one from cap and one from bridge as shown in ur picture
PS. You should add fuses in primary and secondary. You are dealing with high currents
tom_s
Joined Jun 27, 2014
288
my bench supply is similiar to this using lm317/337 mj15003/15004's
R!f@@ 's comment about fuses should be noted (read as a requirement - common sense)
edit: no need to 'open' the transformer, from the look of the picture, the two windings have already been soldered together on the 20v secondary side (centre wiring - 2 wires twisted and soldered) just need to break that connection and parallel up as per your diagram.
ortiko
Joined Oct 21, 2014
66
Fuse are in schedule from the beginning of this project :)
They will be added at the chassis when it will be ready... (pics of it are coming soon)
I will give it a shot with secondary of transformer this evening
Thanks for the advice
R!f@@
Joined Apr 2, 2009
10,010
As said, you do not need to dismantle the whole TX.
The center tap is accessible easily. Just use the iron and untwist the secondary with pliers and you can connect as per ur diagram.
ortiko
Joined Oct 21, 2014
66
This is the old pc case that will be used/modified
New frontage
New frontage cuted...
drilled for the case..
R!f@@
Joined Apr 2, 2009
10,010
Power Supplies use toggle switches.
Safer and better.
I wonder why you need to use a relay.
Using that circuit requires the power applied to TX always. If this is not a problem for you, you can use a resistor of appropriate value. Power can be taken from the capacitor.
Another option is to use a smaller Tx as the standby PSU
R!f@@
Joined Apr 2, 2009
10,010
Mind you a PC uses push button switches which are temporary.
That circuit requires a toggle switch.
A PC power button will just on the relay when pressed and switch off the relay when the button is released.
So I believe you are better off with a power toggle switch
