Simple Bench Power Supply 10A
ortiko
Joined Oct 21, 2014
66
The reason is that on my case there is a nice button includs led that i would like to use but it is computer case switch .
If it is complicated to build electronic switch i will not
R!f@@
Joined Apr 2, 2009
10,010
It is a bit complicated to make a latching relay with just a push button.
It is far better to use a rocker switch. Safer better and less of a hassle.
ISB123
Joined May 21, 2014
1,236
You configured it for 60V/8A.
Or you were thinking to add more Amperage?
Or I'm just wrong since i have no idea about transformers pinout.
PS
OK,I'm wrong didn't realize you wanted negative out.So just ignore what I said....
ortiko
Joined Oct 21, 2014
66
After that i connected everything to test and the test rezualts were very disapointing... :(
with 4A load in about 30sec the MJ15003 gets very HOT :mad:
Very HOT
My load 50W 12V
I am very disappointed an think that this circuit is not good at all
Only the transistors get very hot.
Not the L200 either the emitter resistor.
Except the above problem with a very slight movement of the potensiometer the voltage changes very fast.
Maybe i have made a mistake with connections but i have double checked it
Lestraveled
Joined May 19, 2014
1,946
With all linear power supplies, the voltage NOT being used, times the load current is the heat the pass transistor will dissipate. So, 4 amp times 18 volts equals 72 watts.
ScottWang
Joined Aug 23, 2012
7,505
When you building a liner power supply, whatever you using 2n3055 or mj15003 to be the power transistors, the heat problem always be there, so you need to in parallel with two more mj15003, when the power transistor pass through 1A current will get a lots of heat, make the transistor continuing working temperature under 60℃ to keep the using life of transistor, you may need a fan to blow the heat sink and reducing the heat.
ortiko
Joined Oct 21, 2014
66
Ok. Understood about heat problems. Maybe i will add 2 more mj15003 but there is one more problem i found while testing
If i turn off the potentiometer for current limit the current go down as expected but if i turn it back on with load connected the current doesn't rise...
ortiko
Joined Oct 21, 2014
66
I Could not understand what exactly must be connected at this point with red circle.
I did only connect R4 bottom and not R2 top since i think it is ok from schematic
Someone could be a big help debugging this one...
Johann
Joined Nov 27, 2006
190
If you want greater reliability, exchange the bridge for 4 diodes, stud mounted. (2 x Anode Stud and 2 x Cathode Stud). Mount each pair on its own isolated heat sink; your case looks big enough. At 30A, the tags on the small bridge have a tendency to overheat.
38,834
After paralleling them if you measure 30VAC on the secondary winding you are good to go.
Mind you if one winding can handle 8A you can draw max of 16Amps by paralleling them
Not if the transformer is driving a rectifier-capacitor supply. You need to derate the DC output to about 60% of it's maximum ampere value to allow for the high RMS current that the high peak current draw of a rectifier-capacitor supply causes (because the transformer power dissipation is proportional to the square of the instantaneous current draw, not the average). Thus a 16A transformer is good for about 9.6A DC maximum, close to the 10A the OP wants.
38,834
I dont have any problem with the bridge. It dosent get even hot...
Only transistors get very hot
Sounds like you need a fan blowing on the heatsink, as previously suggested. Mount the fan in the case so it blows outside air directly on the heat sink fins. Use a large muffin fan with a high air capacity.
ortiko
Joined Oct 21, 2014
66
I found out by searching the circuit that i have a mistake with connections of R4
As written from the author R4 and R2 top i thought this must be connected parallel....
Below i have drawn the connection and will make changes this afternoon :)
Hope this will solve the very short changes of current with very small movement of the potentiometer.
ortiko
Joined Oct 21, 2014
66
I will definitely use a blower and also i am thinking of connecting it with thermal resistor to start at 40 celsius
Or maybe less than 40?
Thanks for your suggestions
