I try to use the si5351 as an oscillator with the sa612 (I attached the circuit below). I got myself a breakout board from adafruit for the si5351. IIf you have a look at the attached schematic you can see (on the left hand side) a 0V to 3.3V square wave voltage at 20kHz. That goes into a 220k resistor, because the sa612 expects a 200-300 mVpp signal.
Now I have tried two different implementations of V3 (signal source in the schematic). First I use a signal generator (Siglent SDG 1032X) with a high z output configured. I attached the waveform that appears after C1, called generator.png. Finally I read the analog signal with an ADS1115 breakout board into Arduino. That is shown in the picture called generator_reading.png. There is a curve, because I lifted the transmitter antenna. Anyways, thats the favoured output I want. That's the goal. Now I want to change the signal source, away from a signal generator, to a chip.
So I used the si5351 as a clock generator. I programmed it to generate a 20kHz square wave (0V - 3.3V). The same as the signal generator was set up to. The attached picture called si5351 is the signal after C1 (just as above). There is a difference in signal strength, which might or might not matter for the actual problem.
The real problem is the reading I get. The picture called si5351_reading.png shows part of a sine wave which is present even though I hold the transmitter rather steady. The sine wave has a period of 6 to 7 seconds, and doesn't change much to my movement.
My question is: Where does the sine wave come from ?, and how do I get rid of it ? I essentially want to mirror the behaviour of my function generator with this chip.
Note: If you have another chip recommendation, keep in mind that it would be favourable to produce 3 different independant signals (which can range between 20kHz and 100kHz) cheap. This chip can do 3 independant clock frequencies. I don't want to lose that capability, so I would love to hear suggestions on how to change the circuitry around it.
-8
EDIT: the s5351_reading.png is not the full picture. I couldn't capture the full wave, so it's only part of it. But is does get back up and down and so on.
EDIT2: The opamp used is an AD8615, that's what I had on my hands.
-8
