Are you considering purchasing a new PCB? The reason I ask is from your layout it looks like a simple mod to repair.What's a few more bucks for another run
SG
That's the plan, yeah. What sort of repair could I do?Are you considering purchasing a new PCB? The reason I ask is from your layout it looks like a simple mod to repair.
SG
The pads and joints on the bottom are all fine, it may just be flux and camera effects. The bottom is a full pour, no traces, it's a single-sided board. There was 1 trace I routed weirdly, from C1 to U1, where it goes between the pads of R4, R5, and C2 but I did a bit of googling to see if it would be an issue and it seemed like it should be fine.Looking at the back picture, it looks like (to me) that the copper pour joins all the pins. I don't see clearances between any of the pins on the bottom and the backplane...
And I agree, you have a capacitor from +5V to the VCC pins, there will be no VCC on the micro at all with a capacitor blocking the DC voltage.
So is the bottom a copper pour or is there no traces at all on the bottom (single layer board?)?
if you only need C3 for VCC then just cut the trace going to 5V and jumper it to gnd.That's the plan, yeah. What sort of repair could I do?
Yeah... About that flux! You need to clean it off after soldering. An old (or new) toothbrush with a little alcohol (not the drinking kind) will clear it off in a jiffy. Wipe after scrubbing with a soft cloth.The pads and joints on the bottom are all fine [maybe], it may just be flux and camera effects. The bottom is a full pour, no traces, it's a single-sided board [but you’ve soldered components there]
I had run out of alcohol before I assembled this, but picked some more up so I could clean it properly for rework.Yeah... About that flux! You need to clean it off after soldering. An old (or new) toothbrush with a little alcohol (not the drinking kind) will clear it off in a jiffy. Wipe after scrubbing with a soft cloth.
There’s a lot of extra solder. You can clean it up with a bit of solder wick. And some joints are “balled up”, a sign of excess solder. Reheat those joints and wick up the excess. You can always add a tad more if necessary. A good solder joint “tents up” to the lead.
I think I see a few possible shorts and solder whiskers but I can’t be sure until the flux is cleaned off.
Sorry if I was being oblique. My comment was in reply to “it’s a single sided board”. Not disagreeing with that statement, but you need to also look at the soldered through hole connections.I had run out of alcohol before I assembled this, but picked some more up so I could clean it properly for rework.
I don't understand your comment in my quote "[but you've soldered components there]". The traces for all the through-hole components are routed on the top layer. The holes are plated, so there's an electrical connection from each through-hole pin to its trace. How else am I supposed to attach through-hole components to a PCB?
The short was found already to be in the micro-usb plugdjsfantasi said:Test to see if that’s an issue.
Yes, but this process will help in his next project. Assuming there will be a next project.The short was found already to be in the micro-usb plug
