Schmitt Trigger with Constant Current Source.
Prasanna K Routray
Joined Sep 17, 2015
21
Hi All,
To realise the below circuit I designed a circuit in MultiSim and tried ti simulate. But I'm unable to do so. I would appreciate any help in this regard.
Prasanna K Routray
Joined Sep 17, 2015
21
Hi bertus,
Thanks for the quick response but if I remove the feedback how can I use the feedback?
The SPDT switch has to be controlled automatically because of the voltage swing by Schmitt Trigger.
If you could tell me how to solve the problem or any suggestion.
38,864
In the original schematic, the line from the output to the switch is not a connection, it indicates that the output state is controlling the position of the switch.
You need to change your schematic to reflect that.
bertus
Joined Apr 5, 2008
23,013
The feedback for the switch should come from the output of the inverter.
You have connected it at the input of the inverter.
Bertus
Prasanna K Routray
Joined Sep 17, 2015
21
Hi, Thanks for the reply.
Can you please help me in drawing the schematic because even after looking for a circuit I could not find any. I may be using inappropriate keywords while searching on the internet. I would appreciate your suggesation.
bertus
Joined Apr 5, 2008
23,013
Again you have shorted the in and output of the inverter.
Remove that connection and connect the output of the inverter to the control input of S1.
Bertus
Alec_t
Joined Sep 17, 2013
15,158
I don't see any any triangular wave from that circuit (using generic NPN and PNP), Eric? LTS is telling me vc rises to ~3.4V and stays there.
38,864
What is the polarity of the S1 control input versus the position of the S1 wiper?
Try interchanging the two control inputs (U3A output to - and ground to +).
ericgibbs
Joined Jan 29, 2010
21,600
hi PKR,
Your post #14, simulation voltages are not the same as my posted sim.
You are using a +/-15V supply on the OPA, my circuit uses a single +5V supply
How do you expect the Current Mirrors to work correctly as they are only powered by +5V., when subject to a +/-15V control voltage.?
Also what are the specifications of the 4 transistors.?
E
ericgibbs
Joined Jan 29, 2010
21,600
hi Alec,
I do not use the Generic transistors in my sims. never sure about their claimed performance, had some problems in past using the generics.
Prefer to use known types, same applies to the MOSFET's.
E
Alec_t
Joined Sep 17, 2013
15,158
Likewise, Eric. However, your post #10 circuit shows R4 input as vc, not vc2. The generic transistors work fine in your circuit if R4 input is vc2.
Prasanna K Routray
Joined Sep 17, 2015
21
hi PKR,
E
I modified the supply and changed the transistors also. Still unable to simulate.
