Schmitt trigger using two output OP amp
ashish123456789
Joined Nov 6, 2024
11
hi everyone, I am making Schmitt trigger using LT1713 and it has two output and a latching. I don't know much about schmitt trigger using this kind of op amp. but not getting the expected signal. i want latching of 10us. and reference voltage is 60mv
35,217
“latching of 10us” is confusing.
Do you want an output pulse of 10us?
If yes, you need a pulse generator such as a monostable multivibrator.
schmitt trigger
Joined Jul 12, 2010
2,256
This. What Mr Chips has suggested.
That is; If we are understanding the TS’s problem correctly.
Which I am afraid we are not. Because the behavioral description is that of a monostable, not a schmitt trigger.
28,415
I do not understand why the TS is trying to use a complementary op-amp as a pulse generator.
MC has it right in post #8 Use a device created and optimized for exactly that purpose. With most linear devices the characteristics needed for a stable pulse generator are not all defined in the data sheets, meaning no promise that they are controlled or constant from one device to the next.
ericgibbs
Joined Jan 29, 2010
21,590
Hi Bill,
Have you noticed the amplitude of his 'trigger' signal which is a 100mV pulse of 5nSec and his Vref of 60mV
I would conclude it is the TS's intention by using this low level Comparator,
to avoid adding preamplifiers to raise these levels to logic for these devices CD 74LS 74HC , 74HCT
As I have posted before, read and understand the TS's requirement and intention.
E
28,415
STARTING AT POST #1 i SAW no mention OF THE SIGNAL AMPLITUDE. I SAW THE REFERENCE WAS 60 MILLIVOLTS, but no description of the signal amplitude.
28,415
In general, the standard process for seeking a solution to a problem is to state that problem in accurate detail. This is the standard approach of those folks seeking solutions that I have worked with in the past. It could begin with the statement I need to separate good parts from bad parts, and then usually provide some description of what variables needed to be measured and compared to a standard.
So the first step would be to tell us the goal, and then explain what would be the trigger.
"I need to generate a ten millisecond pulse when (this event) happens." would have been a great beginning.
So don't jump on me for missing something hidden in a simulation file that i can not open.
