- Joined Jul 18, 2013
- 30,688
Under N.A. code you can set up a new neutral see post#5,. one secondary terminal is connected to the earth ground conductor immediately at the Tfmr terminal.use a transformer to convert 220 to 110v and use the earth wire to the casing for safety.
You don't need a neutral.
IIRC it is also allowed in UK.
The two conductors are then taken from this point, Earth and Neutral.
