Hi. Is the voltage applied to an antenna, any antenna whatsoever, always alternating? That is, the voltage going from say positive, then negative, then positive. Thanks. Rich
Isn't varying DC called AC? Anyway, you need a time-variant voltage to excite an antenna.Are there any products or systems in the wireless world, where the rf excitation to the antenna is not ac? But, varying dc?
I suppose at the receiving end, the signal from the antenna will always be ac? Well, I know, it is.![]()
Would you call 100V ± 5V AC?Isn't varying DC called AC?
If the ± 5V is a tolerance, then "no". If the ±5V is an AC voltage on top of 100V, then "yes". If you can pass a signal thru a capacitor, then it is an AC signal.Would you call 100V ± 5V AC?
In that case there is no such thing as DC as all DC will include some noise.If the ± 5V is a tolerance, then "no". If the ±5V is an AC voltage on top of 100V, then "yes". If you can pass a signal thru a capacitor, then it is an AC signal.
Most batteries output fairly pure DC.In that case there is no such thing as DC as all DC will include some noise.
Plus noise. There is no escaping noise.Most batteries output fairly pure DC.
Sure, the transmit antenna could be a tuned coil from the dc power supply to a transistor collector like was common some older RF remote controls. RF with a DC component passes through the coil/antenna but only RF is transmitted.Are there any products or systems in the wireless world, where the rf excitation to the antenna is not ac? But, varying dc?
| Thread starter | Similar threads | Forum | Replies | Date |
| H | Need help to design an array antenna | Wireless & RF Design | 1 | |
Patch antenna phased array | Wireless & RF Design | 8 | |
| B | Antenna SWR | General Electronics Chat | 2 | |
Broken U.FL / IPEX antenna cable connector on Meta Quest 2 controller – repair options? | Technical Repair | 0 | |
TV Antenna Amplifier | Technical Repair | 5 |
