RF converter(mixer), i learn here rf mixer, but this one is a little complicated help
michael1978
Joined Jun 29, 2014
309
I learn here about rf mixers,
and i take from one book complete receiver, so only one little bit i dount understand, it is complicated
here i put the circutis
i select with black line, what i dont understand, can somebody help me a little bit, so i put also in pdf if you dont see picture
Ylli
Joined Nov 13, 2015
1,092
Q3 is configured as an oscillator. The oscillator tuning uses parts L1x (FM Osc), C3, C17, C18, C24, and varicap D3. Incoming RF is also applied to the emitter of Q3, and is mixed with the oscillator by non-linear operation of Q3. The output at the IF frequency is couple through T1 to the rest of the receiver.
michael1978
Joined Jun 29, 2014
309
OOOhhhn Thank youuuuuuuuuuuu………………God bless You...…..
i have just more question, do you see L2, what is that to block high frequency of something else,
do exist formula for oscillator wich sort is, clapp oscillator , of other one? and also for L2 is any formula?
i forget and L4 C16 C23 what form tank circuit? if yes wich resonance must be?
AlbertHall
Joined Jun 4, 2014
12,624
L2 is tuned by C22 and C17A to the desired RF frequency. This passes only the receive frequency on to Q3, the mixer/oscillator.
bertus
Joined Apr 5, 2008
22,917
For better understanding of the RF path, The powersupply rail and the ground are connected together for RF by C2, the 0.1 uF capacitor.
For RF L2 and the combination C22 and C17A are making a parallel resonance circuit.
Bertus
michael1978
Joined Jun 29, 2014
309
Bertus
Hi Bertus....Thanks,
what dou think about, about L4 C16 C23 what form tank circuit? if yes wich resonance must be?
bertus
Joined Apr 5, 2008
22,917
I think L4 and C16 are a filter for rejecting IF back.
(no value of L4 is given, but the circuit has a fixed frequency).
C23 is a coupling capacitor.
Bertus
michael1978
Joined Jun 29, 2014
309
Bertus
GoodMorning Bertus, now almost i understand all, i go to search on google for more detail, Greetings....:):):);)
michael1978
Joined Jun 29, 2014
309
Bertus
Hi, i search in google, i dont understand so good, filter for rejecting if back, i know lowpass highpass bandpass, but what for resonance must i select? is any formula
bertus
Joined Apr 5, 2008
22,917
Look for "notch filter".
A notch filter can be a parallel resonance circuit in series with the signal path or a series resonance circuit accross the signal path.
Bertus
michael1978
Joined Jun 29, 2014
309
Bertus
Ahh notch filter i hear about it,now i gonna find on internet, thnxxxxx have a nice day
danadak
Joined Mar 10, 2018
4,057
Basic response of a notch filter, basically used to suppress a narrow range
or specific frequency. A similar, but not same, is a "Band Stop" filter, used
to suppress a range of frequencies.
Regards, Dana.
michael1978
Joined Jun 29, 2014
309
Regards, Dana.
Hi, Dana, and which are those frequency in this circuit?
michael1978
Joined Jun 29, 2014
309
Hello Ylli, RF is applied to the emitter and L1x (FM Osc), C3, C17, C18, C24, and varicap D3 is apllied to collector?and output is from collector? i dont understand because i thougt the signals must be input to rf to base and local oscillator to emitter like i learn here and internet?
Ylli
Joined Nov 13, 2015
1,092
There are three basic transistor amplifier configurations. Common Emitter (CE) where the emitter is 'grounded', the input is to the base, and the output is from the collector. Common Collector (CC) where the collector is 'grounded', the input is to the base, and the output is from the emitter. Then there is the Common Base (CB) configuration. Here the base is 'grounded', the input is to the emitter, and the output is from the collector.
In this case, the circuit is configured as an oscillator, and input is to the emitter as if this were a Common Base amplifier. The fact that it is also oscillating, and with normal nonlinearities, the stage asks as a self-contained converter.
michael1978
Joined Jun 29, 2014
309
OOh sorry now i undestand more, this is an oscillator and is determined by L1x (FM Osc), C3, C17, C18, C24, and varicap D3 (you told me also in begin), those have one frequency right and this oscillate, but where is the second frequency to mix it? this now i dont understand....
AlbertHall
Joined Jun 4, 2014
12,624
J
Just because it is common collector doesn't necessarily mean that the collector is grounded.
The circuit below is a grounded emitter, common collector circuit. Its characteristics match 'common collector' - high input impedance, low output impedance.
michael1978
Joined Jun 29, 2014
309
J
Hi Albert, i try to understand that circuit oscillator so i build in ltspice, i dont know how to correct it, to understand good, and formula,
i build this one
