Yeah, I know. Was just trying to keep it simple.Just because it is common collector doesn't necessarily mean that the collector is grounded.
Goodmorning Albert, yes i see man, perfect, so this is the correct circuit right?, but one question the tank circuit must be resonance at 110.7mghz, of 10.7mghzTry this one. simulate between 1.7ms and 1.701ms but be patient, it takes a while to plot. You can see that the two frequencies have mixed.
Hello Ylli, i take from the book, i did not design, but only the things wich i dont understand i put it hereWhere did this design (schematic in post #1) come from?
Thank you DanaIn the #14 post those curves are for a notch filter.
Top curve is magnitude freq response, bottom
graph phase response.
Regards, Dana.
A circuit which works is the correct circuit.Goodmorning Albert, yes i see man, perfect, so this is the correct circuit right?, but one question the tank circuit must be resonance at 110.7mghz, of 10.7mghz
So your circuits is working not mine, i download your circuitsA circuit which works is the correct circuit.
A super-heterodyne radio receiver works by having a local oscillator some fixed frequency away from (above or below, doesn't matter which) the intended receive frequency. When this oscillator signal is mixed with the incoming signal it produces (among other things) a fixed frequency intermediate frequency (IF). For VHF FM reception this IF is commonly at 10.7MHz so this must be the difference between the oscillator frequency and the received RF frequency.
Note that the original circuit has a fixed tuned transformer in the collector of the transistor. This is tuned to the IF frequency and passes on signals at the IF while rejecting the other signals at the output of the mixer.
Goodmorning Dana is this graph in orde i make for 88-108mghz
Goodmorning Bertus, i find notch filter so i design, but For RF L2 and the combination C22 and C17A are making a parallel resonance circuit.Hello,
Look for "notch filter".
A notch filter can be a parallel resonance circuit in series with the signal path or a series resonance circuit accross the signal path.
Bertus
He got it here: http://n0gsg.com/ecfp/ch9_sample.pdf , last couple of pages. But it's only a preview and stops in the middle of the description of the receiver.Hello,
Where did you get the schematic in the first place?
Is there no more information to find?
There are some values missing from the schematic.
Bertus
Hi, BertusHello,
Bertus
Yes i know, what do you think, they explain if i buy the book all in details,...…...i dont know to buy of not, they explain everythink of not,He got it here: http://n0gsg.com/ecfp/ch9_sample.pdf , last couple of pages. But it's only a preview and stops in the middle of the description of the receiver.
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jake Hertz
